CAM PROBLEM
Old Jun 27, 2001 | 12:36 AM
SCFORMULA1's Avatar
CAM PROBLEM
DID A HEADS CAM SWAP ON MY 89 FORMULA 305 TPI. PUT A LT4 HOT CAM IN, 1.6 ROLLER ROCKERS, HEADS PORTED AND POLISHED WITH BIGGER INTAKE VALVES...... WELL PROBLEM IS TIMING IS SET CORRECTLY BUT THE CAR IS STILL RUNNING LIKE %^&%^. DO I NEED TO HAVE A CUSTOM BURNT CHIP OR WHAT IM NOT SURE. ABOUT TO GO OFF DEEP END PLEASE ANYYONE HELP.
MODS: SLP INTAKE RUNNERS,PORTED AND POLISHED HEADS, LT4 HOTCAM,EDELBROCK HEADERS,1.6 ROCKERS,RAM AIR,3.73 GEARS AND AUBURN W/SHIFT KITS.PLUS SOME OTHER SMALL STUFF
Old Jun 27, 2001 | 01:51 AM
Guest
Guest
Posts: n/a
A 305 with a Hot cam? Yea, thats gonna need a chip to run right. You may be able to adjust the throttle plate, the timing and the TPS but its going to be far from ideal.
Old Jun 27, 2001 | 02:02 AM
SCFORMULA1's Avatar
THATS WHAT I THOUGHT, I M GOING TO PUT IN A ORDER FOR ONE LATER TODAY. MY FRIEND AND I HAVE BEEN TRYING TO GET IT RUNNING RIGHT FOR THE PAST WEEK. THANKS
Old Jun 27, 2001 | 02:06 AM
Guest
Guest
Posts: n/a
Order from who? Keep in mind the 'performance' chips sold through places like Hypertech, ADS, Jet, etc etc will not help, it has to be a custom burn from someone who knows what they are doing.
You can try opening up the throttle plates by about 1-1.5 turns of the stop screw, and lowering the TPS setting to about .3-.4V and that may work as a band aid for now.
Old Jun 27, 2001 | 07:28 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
What kind of heads are you running. The stockers? Did you have the guides milled down for all the lift of that cam and the proper springs. You must have some serious lift with 1.6rr's.
Old Jun 27, 2001 | 11:47 AM
SCFORMULA1's Avatar
THE HEADS ARE THE STOCK ONES, THEY HAVE BEEN VATED, A 3 ANGLE VALVA JOB, CUT THE SPRING POCKETS PORTED AND POLISH NEW MANLY STREET FLOW VALVE INTAKE VALVE ARE ALSO BIGGER THAN STOCK ( 1.94)I M USING THE SPRINGS THAT CAM WITH THE HOT CAM.
Street Lethal
Apr 30, 2019 12:14 PM
nuggie
Aug 25, 2015 01:27 PM
neekolzun
Aug 24, 2015 04:59 PM
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
