How to plumb vacuum for MAP on older TPI plenum.
Old Jan 20, 2008 | 07:22 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I am using a 85 plenum on a SD setup, and I'm not sure if it makes a difference what source I tap into for the MAP vacuum supply.
Any opinions?
I've looked around and can't find answer, and have been given several opinions, but not from you guys. The answers are here!
Help
Ron
Old Jan 20, 2008 | 08:19 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: How to plumb vacuum for MAP on older TPI plenum.
On mine I used a T and tied into the supply for the HVAC control.
Probably not ideal. I'm not sure if the HVAC could interfere and cause a false reading at the MAP.
Old Jan 25, 2008 | 08:08 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
anywhere it's getting good vacuum like where the fpr gets it vac.
Old Jan 25, 2008 | 10:26 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I used an '89 TPI on my conversion and had to drill and tap for a third fitting as things weren't operating as they should. MAP needs it's own vacuum source as did my FPR, mine ran really bad with any sharing of vacuum. The third line feeds the HVAC and the accumulator and all is well.
Old Jan 26, 2008 | 08:14 AM
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
You know, drilling another hole for it makes a lot of sense.
I was afraid I might split off the MAP or FP vacuum.
I did that on my marine ramjet intake. The marine unit didn't have a vaccum port for brake booster. Who needs power brakes on a boat!
Thanks guys.
mdtoren
Aug 23, 2015 12:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
