water boiling
Old Jul 5, 2001 | 01:14 AM
matlock's Avatar
Car: 89 GTA
water boiling
I just bought an 89 GTA and after driving it for a while I parked it and noticed the water was boiling very loudly. And touching everything near the engine was very hot, even the fenders. The coolant is a light brown mucky color. Anyone know what the problem is? I'll flush and replace the coolant asap.
Old Jul 5, 2001 | 09:04 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Familiarize yourself with what the airdam is located underneath the car and see if you have one or yours is damaged. It is critical for cooling operation. It scoops air into the radiator from underneath.
Old Jul 5, 2001 | 09:17 AM
matlock's Avatar
Car: 89 GTA
I'll check for that. I didnt notice the car overheating when I was letting it idle while checking it out for a while. I made sure I let it idle for a good while, but I never got a chance to drive it extensively till now.
Old Jul 5, 2001 | 09:30 AM
matlock's Avatar
Car: 89 GTA
Yeah there is an air dam at the bottom of the radiator. Before I bought the car I had it checked out and a compression test done on it. The compression test turned out great, so should I be worried about a cracked block or blown head gasket? The car goes pretty good when I floor it, but it seems the pedal has a bit of a dead spot in the middle. I guess that could just be the timing. Thanks for any help.
Old Jul 5, 2001 | 12:19 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Follow this diagnostic tree:
Car Overheating
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
84redta
Sep 19, 2015 09:58 AM
