Large cap HEI and TPI???
Old Jul 8, 2001 | 02:16 AM
67muscle's Avatar
Will a TPI fit with a HEI distributor?
Old Jul 8, 2001 | 07:22 AM
nitroscj's Avatar
yes
Old Jul 8, 2001 | 07:49 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
You mean the ld style HEI with the coil in cap? I don't think you would clear the extension off of the plenum. That style HEI has a pretty tall cap. IF you don't mind deleting the extension, I think it would fit...
Old Jul 8, 2001 | 10:31 AM
Guest
Guest
Posts: n/a
Yes, it will fit just fine. The 85 and 86 cars came from the factory with the coil in cap HEI.
Old Jul 8, 2001 | 10:32 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
It'll fit, as long as were talking about the early TPI coil-in-cap distributor. I ran one on my 305 TPI for a couple years. It should fit with a factory coil, but won't clear if you use a Supercoil, you'll need an aluminum cut-off plenum extension. Bought it from Jeg's for $18 2 years ago. Made specifically to clear Supercoils. I have 3 of the damn things in my garage. This 'large cap' is the coil-in-cap HEI distributor, right? The only problem I forsee is the connector...it changed around '86, so make sure it'll fit...
Old Jul 8, 2001 | 12:41 PM
67muscle's Avatar
Well here's the deal I'm gonna put tpi on my 67 camaro and I got the early style non-computer controlled HEI with the coil in the cap. I'm using an Accel brute thunder coil that fits stock unlike the supercoil that's taller. So I guess it'll fit.
Just FYI I'm going with an SDS computer that just does fuel management.
Any tips anyone could give would be great
Azrael91966669
25
Jun 20, 2017 04:04 AM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
Sanjay
Aug 12, 2015 03:41 PM
