1-LE Z28,WHAT ARE THEY WORTH?
Old Jul 6, 2001 | 12:19 AM
Flip71ss's Avatar
I FOUND A 1990 1-LE Z28 AND WONDERED WHAT ONE WAS WORTH IT IS A 305 AUTO CAR AND IT IS RED AND HAS AIR AND EVERYTHING.THE ENGINE HAS A LITTLE KNOCK IN IT BUT IT CAN BE BOUGHT FOR $300.WHAT DO YOU THINK?
Old Jul 6, 2001 | 03:15 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
1LE with Air, & auto, I would be skeptical. Look at the bild sheet to be sure.
The car is only worth what someone is willing to pay for it. If you like it, buy it. Sounds like is has been beat on a little, so a complete overhaul might be in order.
ACTUALLy, if it has TPI, which it should, get it, the worst that will happen is you will make about $700 on the parts, the SD intake with wires & computer in good condition on e-bay will bring $500
my $.025
[This message has been edited by okfoz (edited July 06, 2001).]
Old Jul 6, 2001 | 11:39 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Heck, even if it's not a 1LE, a $300.00 Z28 isn't a bad deal.
but then again I haven't seen it either
Old Jul 7, 2001 | 09:29 PM
leirch's Avatar
Yea like Mike said, for 300bucks it would be worth the yard space!
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 8, 2001 | 12:06 AM
LeftTurn1LE's Avatar
No its not a 1LE. In 1990 only 34 were built with a 305. 28 were built with a 350. The 1LE did not come with A/C. Another easy way to tell is that the 1LE didn't have fog lamps. On the bright side, for $300 it doesn't matter. If you like it, get it. If its knocking just get a new engine.
Old Jul 8, 2001 | 09:40 AM
Gary Anderson's Avatar
LeftTurn1LE,
I just bought a '90 1LE. It has some decals in the spots where the Z28 badges would normally be that say just CROYCO. Any idea what CROYCO is or means? The previous owner had no idea, just that they were on the car when he bought it. Thanks.
Regards,
Gary Anderson
Old Jul 8, 2001 | 12:28 PM
88IROCs's Avatar
Gary,
There is a Croyco Motorsports in Sturgeon Bay, WI. I would contact them to see if they raced your car. A bonafide race history will definitely boost the value of your car.
croycomotorsports@msn.com
Old Jul 9, 2001 | 01:41 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
didn't know they even made 305 automatic 1LE's
CAMAROBEAV
European Region
Apr 29, 2021 04:54 PM
Orr89RocZ
Sep 13, 2015 09:41 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
dementednut
Sep 10, 2015 09:50 PM
