Corvette starter?
Old Jan 27, 2008 | 01:01 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Corvette starter?
Has anybody used a starter from an '88-'91 Corvette on their L98. The original Camaro starter has 9 teeth, and the Corvette starter has 11 teeth.
Old Jan 27, 2008 | 04:03 PM
TPeye's Avatar
Engine: 350ci
Re: Corvette starter?
I'll answer my own question. With a little bit of shimming the starter does fit. It starts up much quicker now, and the 8 lb weight reduction is always welcome.
Old Mar 3, 2008 | 12:12 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Did your starter have the solenoid on the bottom?
Did you have to make your wires longer?
Old Mar 3, 2008 | 11:48 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
This is what I did and it works great.
https://www.thirdgen.org/forums/tech...r-upgrade.html
Old Mar 4, 2008 | 07:44 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I ran across your post after I posted in this one. Looks like I will be fine.
Are you running headers? LT's or shortys?
Old Apr 5, 2017 | 02:19 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
I used GM P/N 10455702 on my '88 L98....other than the different length bolts, it was a straight swap. I've had zero starting issues since.
Old Apr 10, 2017 | 10:34 AM
Car: 1988 IROC-Z
...says the man who accidently bumped a 9-year-old post...sorry!
3rd gen money
Oct 11, 2019 09:57 PM
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
