NEED HELP FAST!!!!!!!!!!!!
Old Jul 10, 2001 | 08:59 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I had purchased a 87 GTA with a 350 TPI and digital dash,it had a engine fire. My problem is that on the ecm wiring there is a connector that has 6 holes but only three are used, i think the wire colors are tan, pink, and purple. these go into the main harness to the engine. there is also one i think for the ses light ect. What does it do and where does it go, I bought a wiring harness from a 87 Iroc 350 TPI but it does not have it. PLEASE HELP!!!!!!
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire hope to get running soon
Flowmaster exhaust
Old Jul 10, 2001 | 09:07 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
OK, If we are thinking about the same connector, it is under the dash on the right side, there are the two standard flat connectors as well that plug into the dash wiring harness. The Engine wiring harness plugs into these connectors and then the engine wires plug into the ECM.
OK
I traced those wires back one time and I think all three go to the fues panel for the Fuel pump and something else.
NOTE: I did trace a non-digital dash, they should be the same if they used the same engine wiring harness, I suspect they did.
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
[This message has been edited by okfoz (edited July 10, 2001).]
Old Jul 10, 2001 | 10:01 AM
AaronIROCZ's Avatar
I double checked the wire colors and they are 2 pink with a black stripe wires and 1 brown wires.
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
MINI RAM SOON!!!!!
Flowmaster exhaust
Old Jul 10, 2001 | 11:43 PM
AaronIROCZ's Avatar
ANYBODY!!!!!!!!!!!!!!!!!!! WHat is the brown wire for? where does the Iroc injectors get + power?
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
MINI RAM SOON!!!!!
Flowmaster exhaust
[This message has been edited by AaronIROCZ (edited July 10, 2001).]
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
