K&N Breather Filter...
Old Jul 10, 2001 | 01:25 PM
IROCKER's Avatar
I was think of installing one of those small K&N breather filters on my car (one of the ones that goes on the valve cover). Hasn't anyone else done this? And if so, did you just do the side without the PCV valve? Or both? Just wanted to know the pros and cons of this on a TPI engine.
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for front and rear LCAs and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, JET low temp stat, CarSound Hi-flow Cat, DynoMax 3" Mandrel-bent pipes, Flowmaster muffler, 3" chrome tailpipes, T-tops, and White exterior with red leather interior.
2001 Sunfire GT
Bone stock 2.4L, 5-speed, K&N cone filter, interior detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
3rd Place Stock Class at annual 2001 JCO Bash
Web: http://www.angelfire.com/on3/whitelightening
Old Jul 10, 2001 | 10:08 PM
Guest
Guest
Posts: n/a
Cons: Messy messy messy messy
Pros: On a street car, cant think of one.
Why do you want to do that? The stock setup actually works pretty good and is clean to boot.
Old Jul 11, 2001 | 07:55 AM
IROCKER's Avatar
I was only thinking about it, just to keep the inside of the plenum a little cleaner. You say it's messy, in what way?
1987 Camaro IROC-Z
2001 Sunfire GT
Old Jul 11, 2001 | 10:03 AM
chiefz28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by IROCKER:
</font>
well your plenum may stay cleaner inside.I imagine your refering to oil.now instead of being in your plenum it's now all over your valve covers around your breather.
Old Jul 11, 2001 | 11:37 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
And IMO, it won't help to keep the plenum any cleaner either, as gases drawn in through the PCV will still enter through the EGR holes, and PCV represents the majority of the oil in the plenum. The breather side that is hooked to the TB will only get a very small amount of vapor under heavy load/WOT conditions. Since you shouldn't be under those conditions very often, and since the volume of oil vapor is small, i'd say it is negligible and you'll just end up with a mess on your VCs.
Old Jul 12, 2001 | 06:17 AM
IROCKER's Avatar
That's cool guys, that's all I wanted to know. I appreciate you input.
1987 Camaro IROC-Z
2001 Sunfire GT
Old Jul 12, 2001 | 11:30 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
If you use the stock valve covers, or different ones that have baffles, you should not have a problem with making a mess on your valve covers. The baffles in the valve cover do wonders for keeping oil in liquid form from getting into the breather and subsequently, onto the valve cover. Gotta remember that the breather is only designed to filter out oil particles, not oil in liquid form.
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, K+N cone, AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Hotchkis STB.
Old Jul 12, 2001 | 12:19 PM
IROCKER's Avatar
Thanks Matt, I gonna pass on the idea though. Seems too much of a hassle for what it's worth.
1987 Camaro IROC-Z
2001 Sunfire GT
Pac J
May 17, 2020 10:44 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
