Help!! TPI fuel delivery issues
Old Jan 28, 2008 | 10:01 PM
CamaroCarnage's Avatar
i just finished up with my LO3 TO L98 swap, and BOOM! cranks over and fires up absolutely perfect first try. runs a bit rich, but its alright for now. after i let it idle for 5 minutes, i turn it off and try and start it about 5 seconds later, but its completely flooded. i pulled a plug and it was fuel fouled like crazy. i come back the next day and it fires over perfect again, and does the exact same thing. its almost like fuel is getting past the injectors when the car is off. could the injectors be leaking or maybe could the fuel pressure regulator be acting up? i just want to get my car back home for now, and i dont even know where to start. has anybody had similar problems?
Old Jan 28, 2008 | 10:05 PM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
Re: Help!! TPI fuel delivery issues
It sounds like you have a higher lb injectors, or leaky ones. I relpaced mine due to 2 leaky injectors. Replaced them all, because after getting the plenum removed, it was just better getting them all replaced rather than 2 months later doing it all over again.
Old Jan 28, 2008 | 10:21 PM
yeah good call. a guy i know is selling his 19lb accel injectors from his 5liter mustang, and they are like new still. He only wants 100 bucks so i think ill go for it. do you know if these will work decent on a 350tpi setup?
Old Jan 28, 2008 | 10:51 PM
Axle/Gears: 373s
I guess Accel had some bad batches of injectors, and some of the members here swayed me away from them. I ended up buying a remanufactured set of Ford 19lb injectors for 140.00 on Ebay. My L98 350 purrs like a kitten now, and passed emissions with flying colors.
Old Jan 29, 2008 | 09:57 PM
haha yeah kinda late. i bought those accel injectors today. they are a few months old and have barely been used at all, maybe like 2 hours of run time. i paid 100 bucks, and he bought them for 362, and i even have the receipt. the P/N is 150119. i hope these fix my problems...
Old Jan 30, 2008 | 09:57 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
the L98 used 22 LB injectors, those 19 lb ones might be a little small since the PROM is programed for 22 LB, unless Accel rates theirs like Ford does.
There are faily easy tests to see if the injectors are leaking. Better to diagnose the problem rather than just throw parts at it and hope.
Also pull the vacuum hose of the pressure regulator and check for gas... check the plenum as well. That would indicate it was leaking and needing replacement.
Old Jan 31, 2008 | 12:00 AM
alright, well i crossed my fingers and it worked. the new injectors solved all my problems. idles perfectly, doesnt flood, starts every time. im still having one problem though. if i give it gas, it falls flat on its face, unless i progressively increase the throttle slowly. it also backfires through the intake. after about 2500 rpm there is no hesitation. just from an idle.im thinking that its possible the tps? anyone have any input?
Old Feb 4, 2008 | 06:17 PM
rednblackrs's Avatar
Car: 01 mustang GT
Engine: 4.6
Transmission: tr3650
Axle/Gears: 3.73 Posi
Test the TPS I had the same problem and that solved it. All I did was start the car and then grab just the TPS sensor and twist the metal arm on just the TPS and my engine didnt even react knew instantly that it was my problem. If it bogs or floods than the tps is at least working. If you have an ohm meter than you can test it yourself and make dang sure
good luck
Old Feb 4, 2008 | 06:28 PM
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
had kinda the same problem ..
but whenever my car bogs down during acceleration .. i find a vacuum line disconnected ..
i'd test the tps .. check your vacuum lines .. and then make sure your timing and fuel pressure is good ..
i had a "pop" through the intake and it turned out to be too lean when i revved it ..
once you make sure its all good .. and it still pops .. try driving it untill it warms up .. then let the computer adjust to get the right fuel mixture .. i think that is what mine did b/c the pop went away after a few miles of driving ..
EDIT:
actually .. after looking at your last post again .. looks like your injectors are too small ..
even turned all the way up you can only get around 20.5 pounds out of the 19 pound injectors .. and the stockers are supposed to be 22 pounds .. so when its idling, itll get enough fuel .. but when you rev it, your not getting enough fuel and your getting a lean "pop" through the intake ..
try swapping to 22 pound or higher if you got mods ..
hope that helps
Old Feb 4, 2008 | 10:01 PM
ky_kneedragger's Avatar
i am in dire need of a complete engine harness maybe more for a tpi z28...small fire tonight kicked my ***...can anyone help me????
Old Feb 4, 2008 | 10:07 PM
Transmission: 5 spd
painless sells a tpi wiring harness
summit sells it for $367
http://store.summitracing.com/partde...5&autoview=sku
i would think buying a new one would be easier than trying to get a used one with brittle connectors ..
but anything else you should be able to get at a pull apart yard .. or if you want new, you can find almost everything for these cars
Old Feb 4, 2008 | 10:27 PM
yeah i'd say your right,i have had nothing but problems out !!!
Old Feb 4, 2008 | 10:47 PM
i also need a factory air box,well just the bottom section of it.but if i have to get the whole thing i will.where could i find an idex or some type of identification for the vin #'s?
Old Feb 5, 2008 | 07:59 PM
yeah it was the tps. i fixed it a few days ago and finally got it running decent. for some reason the idle decided to drop 400 rpm today, and it was stalling out at like every light. When the car is cold it runs like ^(#%* aswell. as soon as it hits about 1/3 on the temp gauge (stock gauge) it starts running better. when its warm it HAULS. runs flawlessly. its even hard to start it in the morning. it runs for like 5 seconds and dies. im gonna freeak out like a ninja if i dont get it running decent soon.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
