bypassing coolant lines in throttle body
Old Jan 29, 2008 | 11:02 PM
CamaroCarnage's Avatar
Does bypassing the coolant lines in your throttle body effect the coolant temperature sending unit on the side of the throttle body??
Old Jan 29, 2008 | 11:57 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: bypassing coolant lines in throttle body
h2o sender in tb ? everone i've seen is in the base plate under the tb, so no
Old Jan 30, 2008 | 10:49 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Camaro,
Some one correct me if I'm wrong, the coolant passage to your throttle body was routed there for those very cold locations. Most of us aren't running our car mid-winter in Alaska so you wont have any adverse reactions from doing so.
Rabi C.
Old Jan 31, 2008 | 12:04 AM
well i was reading in my haynes manual and it says that there is a coolant temp sender in the tb that helps control the air fuel mixture while the car is warming up... ive never heard of this either. is it true?
Old Jan 31, 2008 | 01:30 AM
rednblackrs's Avatar
Car: 01 mustang GT
Engine: 4.6
Transmission: tr3650
Axle/Gears: 3.73 Posi
I believe you are talking about the pre '87 intakes with the 9nth injector the temp switch was mounted in the front of the lower intake though on the two that I have seen, and one that I own.
There is only 2 "Sensors" one being the idle air control valve (which doesnt really sense anything) and the Throttle position sensor.
The Intake air sensor is in the bottom of the plenum on some and in the air cleaner on others. The one in the plenum would "sense" cooler air and the computer would react accordingly. From my experience and alot of others as well..There isnt much power to be gained from it. Maybe 2 or 3HP
My
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
