Vette or Camaro TPI?
Old Jul 10, 2001 | 07:37 PM
67muscle's Avatar
Well I've heard the Vette TPI base manifold won't fit on a camaro block cause something blocks the oil pressure sensor. Is this true or completely BS?
Old Jul 10, 2001 | 07:58 PM
irocbsa's Avatar
I have never heard of that. The only reason that you can't swap manifolds between Vettes and F-bodies I know of is that the Corvettes have an external EGR and F bodies do not. If you get an aftermarket manifold such as the edelbrock it has provisions for both platforms. What oil pressure sensor are you talking about? The sending unit for the gauge? Not even close to the manifold on my car.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jul 10, 2001 | 09:33 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
on a stock manifold the vette iintake will not bolt up the middle cylinders are at a different angle than the f body due to the aluminum heads however the edelbrock will cure the problem.
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,1 5/8 headers,y-pipe,edelbrock base,hi flo cat,air foil,afpr,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ads strip chip,relocated iat sensor,tb bypass,hollowed maf,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
siamesing the slp's and my fastchip eprom is on it's way
Old Jul 10, 2001 | 09:48 PM
Guest
Guest
Posts: n/a
That depends on the year...
The vette base and any 85-86 F-body base will bolt up to the pre-87 intake bolt style, but not the later one unless you modify the center 4 bolt holes on the intake, which can be done.
Another thing to be aware of is the fuel line connection from the fuel rail, the vette is on the passenger side, the F-body bends over to hook up on the driver side.
Ive never heard anything about blocking an oil pressure sensor either...
Old Jul 10, 2001 | 10:20 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Maybe you are thinking about the Oil Temperature Sensor, which is used on the Vette and their version of the SD 727 ECM but not the F-body and its SD 730 ECM.
I do not believe the Vette MAF system had an Oil Temperature Sensor.
Old Jul 10, 2001 | 10:50 PM
67muscle's Avatar
So ANY vette intake will work then? Or just pre-87 ones?
Also I wsa thinking about getting some aluminum vette heads anything as far as interchangability I should know about before I buy?
Thanks All
Old Jul 10, 2001 | 11:09 PM
Guest
Guest
Posts: n/a
AFAIK all the later vettes got aluminum heads, so the intake is the early bolt pattern. There are no other differences I know of.
The heads will work fine with the vette base or an 85 or 86 F-body base, or a modifed 87 up F-body base... or any aftermarket base. The heads have no provisions for EGR, so keep that in mind if you have any intentions of retaining the EGR function. Theres also an accessory bolt hole missing for the serpentine setup, but thats easily drilled+tapped.
Old Jul 11, 2001 | 01:36 AM
67muscle's Avatar
Thanks.
Whats AFAIK mean?
Also about the accesory bolt hole for the serpintine set-up do the later heads just have the standard 3 bolt holes on each head? or are they a different configuration.
Old Jul 11, 2001 | 08:09 AM
irocbsa's Avatar
AFAIK = As far as I know
Old Jul 13, 2001 | 11:16 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
the fuel rail is also different.on the vette's the hard line coming off of the fuel rail is shorter than the f-bodies.the fuel rial hard line stops right above the timing chain cover and he f-bodies cross over the top of the timing chain cover
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jul 13, 2001 | 09:16 PM
BC86TPI-Z51's Avatar
My 86 Vette with aluminum heads has a large oil pressure sensor on the back of the intake manifold..(left side of distributor)its actually screws into the back of the block and the intake clears it just fine...Im thinking this is the sensor you were thinking about.
The Vette intake also has rear water ports open in them while the F car manifolds did not.
At least to my knowledge the F cars didnt have them..I also have a spare 85 TPI unit off a trans am and the rear ports are sealed so water cant go through it.
Also on the right side of the intake near the EGR port on the vette style is a small hole where a water pipe goes on the back of the intake..im not sure of its purpose but I have that pipe and a coolant hose attached to it running to the heater core area where the other hoses are.I thought it was to help get the air pockets out of there.
That would need to be blocked off if you were going to use a Vette intake.
1986 Vette Coupe,auto, 357 L98 w/alum. heads,40 over,crane cam,3.73 Gears,The usual Mods..
Had an 86 Bird before..want to get another F car again!
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Caspar
Jun 19, 2016 11:19 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
