Good or bad TPI?
Old Feb 2, 2008 | 11:31 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Good or bad TPI?
I dont know if there is such thing as a crappy TPI unit, but I picked up an entire setup for 250 bucks... And I noticed it was equipped with a MAF sensor... Which means it came out of an 86-89. Is that bad?
Old Feb 2, 2008 | 12:26 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Good or bad TPI?
Depends on what ya wanna do. The maf cars are more forgiving of mods.... before prom tuning becomes necessary, but, any car will benefit from some good tuning.
Old Feb 2, 2008 | 01:19 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
So are you saying... The maf cars are somewhat better?
Old Feb 2, 2008 | 01:27 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
I'm no expert on this but I can say that I'm putting TPI on my 87 Monte SS and I chose to go with the maf setup because I didn't want to worry about getting a chip (re)programmed. As said above, the maf system can adjust to slight mods by itself without having to reprogram the chip. One downfall to a maf system is it(maf sensor) is a restriction in airflow entering the intake which will choke more radical motors. But if you are putting this on a stock/slightly modded 305 or 350 you will be fine. HTH
Old Feb 2, 2008 | 02:15 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Sweet... Yeah, it's going on a 350.. Well thats some good info to know there, THANKS GUYS
86IROC112
Apr 9, 2016 10:20 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
