8000 rpms
Old Jul 5, 2001 | 10:04 PM
breathment's Avatar
8000 rpms
Hey guys, why is it that my tach goes up to 8000 while the redline is 6000?
88' GTA 350 MODS---> air foil, K&N, Shift Kit
[This message has been edited by breathment (edited July 05, 2001).]
Old Jul 5, 2001 | 10:14 PM
Guest
Guest
Posts: n/a
They had extra ink?
Dont know. Maybe they figured some people might mod the car and want a tach that read higher than 6000.
Old Jul 5, 2001 | 10:39 PM
whiteroc's Avatar
Hey guys, why is it that my speedometer goes up to 145 MPH while the speedlimit is 75?
Old Jul 5, 2001 | 10:41 PM
breathment's Avatar
<font face="Verdana, Arial" size="2">Originally posted by whiteroc:
Hey guys, why is it that my speedometer goes up to 145 MPH while the speedlimit is 75? </font>
where is the speed limit 75? its only 70 here in tx, and there are trying to lower it again.
88' GTA 350 MODS---&gt; air foil, K&N, Shift Kit
Old Jul 5, 2001 | 10:42 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Probably the same reason your speedometer has numbers the needle will never point to. It looks cool in the showroom!
87 Formula 305TPI T5
Old Jul 5, 2001 | 11:32 PM
leirch's Avatar
Because GM KNOWS your not going to go the speed limit and your going to see what the car can do!
Oh wait.. no mr. officer, that wasn't me.. i wasn't the little maroon blur you saw go by
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jul 5, 2001 | 11:48 PM
whiteroc's Avatar
</font>
Oklahoma -I usually leave the cruise on 80 MPH -5 over will never get a cop away from a donut.
80 MPH? -well at least I'm over halfway there. (145)
Old Jul 6, 2001 | 12:28 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
ooppps
[This message has been edited by Chris Etemadi (edited July 05, 2001).]
Old Jul 6, 2001 | 12:30 AM
Car: 1991 Z28
hey White Iroc I wouldnt say that. In small towns like Warr acres they will put their Kripy Kream down to pull someone over for 4 miles over.
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Jul 6, 2001 | 12:50 AM
whiteroc's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Chris Etemadi:
</font>
I've only done 80MPH through Warr Arches like 3 times. (raced a few mustangs @ 40+MPH over the speed limit & they would Krispy Kream in their pants if they caught me)I was talking about the Interstate -everyone is going 5+MPH over.
Hey man what color is your 91 Z28. I have probably seen you out on 39th expressway.
Have you seen a ROC that looks like this?
http://www.nbizz.com/ezarre/upload/89irocz.jpg
Old Jul 6, 2001 | 09:24 AM
86Z28TPI's Avatar
The posted speed limit in Maine is 75 on most remote highways, even on I-95!
Old Jul 8, 2001 | 05:07 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
just made a round trip to kentucky and back to nj.virginia rt 81 not 1 trooper in sight 115mph made up a lot of time i lost going through tenn. pita troopers
Old Jul 9, 2001 | 12:49 AM
442guy's Avatar
75 mph? 80 mph sped limit? you guys are lucky. here in nyc all the highways are 55mph. some upstate ny have 65 though.
Old Jul 9, 2001 | 01:10 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
<font face="Verdana, Arial" size="2">Originally posted by KNTA4DNU:
</font>
i dunno about you guys, but my cars speedo has pointed out every number on my speedo and then some
Old Jul 9, 2001 | 08:23 AM
irocbsa's Avatar
GA really needs to raise the speed limit here. Sure 70 is nice, but most of the highways here are just open expanses of road with nothing nearby. Especially I-16. Nothing, and I mean nothing for 180 miles. People need to start understanding that speed doesn't kill. Idiots that cannot drive at speed kill. Like soccer moms with F*#d Expeditions.
bsa
Old Jul 10, 2001 | 12:30 AM
cy Z28's Avatar
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
wanna see nothing forever, go to Tex-line, Texas. About five minutes from new Mexico. Then head east on I-20. YOu won't see anything till Midland. Hell you son't see anything till Weatherford or even Hulen Street in Ft. Worth
Cody "cyZ28" Young
'84 black on black Z28
355, 5-speed (on the way out. What goes back in, ooohh baby!!)
http://www.geocities.com/mustang_tbird/codypage.html
Old Jul 10, 2001 | 10:53 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by breathment:
</font>
Are you SURE about the 6,000 rpm redline? L98s got a tach with a "yellow line" at 5,000 rpm and a redline at 5,500 rpm. Sounds like you got a V6 Tach or someone has swapped the engine.
Old Jul 10, 2001 | 03:43 PM
breathment's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
Are you SURE about the 6,000 rpm redline? L98s got a tach with a "yellow line" at 5,000 rpm and a redline at 5,500 rpm. Sounds like you got a V6 Tach or someone has swapped the engine.</font>
ya, i mad a mistake, it does redline at 5500, i looked at it the other day and noticed it.
88' GTA 350 MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Jul 10, 2001 | 04:07 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Well it's probably because the stock tach is so d@mn inaccurate. After reading some info that seemed to say a 305 could go to around 6K, I compared the tach reading to the auto x ray reading and around redline there was about 500 rpms difference. Below 3K there was almost no difference. This really doesn't make sense to me, since it would seem like the ecm and tach have the same info coming from the same wire, but go figure. I guess this is why hardcore folks get a mechanical tach...
Old Jul 10, 2001 | 07:53 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
hey white iroc i saw you at Thunder Valley about 2 months ago. i had the 87 iroc with headers. chris' 91 is black. with the wing on the back not the spoiler.
Andrew
Old Jul 16, 2001 | 08:57 PM
Drakar's Avatar
I'm always jealous about your MPH as in CANADA it is KMH and well to say the least it doesn't sound cool to say I went 160 KMH cause it's only 100 MPH!!!! so I think I will go MPH like the rest of you ..... I could always argue that 110 was posted .... didn't have time to read if it was KMH or MPH
1989 GTA 350 TPI
Stock:
- T-tops
- Dual cats
- 9-Bolt 7.75" Rearend
- 3.27 gears
Mods:
- Dynomax Super Turbo Muffler
1992 RS 305 TBI - Sold
[This message has been edited by Drakar (edited July 17, 2001).]
ULTM8Z
Oct 2, 2015 01:25 PM
Giocio
Oct 1, 2015 12:20 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
