Stock L98 Heads on a '92 B4C Camaro?
Are the stock 64cc heads on a '92 L98 good for say, up to 350HP for a street engine. My friend is rebuilding the engine in his '92 B4C Camaro and was wanting to hop it up a little bit, but not too extreme. He was thinking about a Comp Cams 304 Cam, 210/220, .500/.510 on a 114 LSA. Would it be worth it to port the stock heads or invest in some other heads, again not looking to spend a lot of $$. Just looking for about 300 RWHP.
Sean
'91 B4C 5.0L/5 speed
Sean
You can't use L98 heads on a 305. The chambers are larger and the valves will hit the sides of the block.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: 04 GTO
Transmission: M12 T56
The stock heads aren't that bad, if your friend is sticking with the stock intake then putting a few dollars into cleanup work and a nice valve job should help nicely.
If he's planning on getting more serious then he'd be better off just getting some aftermarket heads rather than sinking money into extensive porting on the stockers.
...ed
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
...ed
The heads will be going on a 350. It is actually my car that b4c1le is talking about. Which aftermarket heads will work well with the aforementioned cam or the ZZ-9 cam. I plan on running the TPiS big mouth intake. Any help or idea's are greatly appreciated.
1992 L98 DGGM B4C (X-FBI car)
1992 X-CHP B4C, Black and White.
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
don't waste your ttime on the iiron l98 heads they will need a lot of help tto flow well.if you dont wanna spend a lot of cash search around for l98 aluminums they flow better an are easier to port to get decent flow out of
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
Yeah but aren't the L98 aluminum vette heads 58cc combustion chambers? I guess you could use a different piston and/or head gasket to keep the compression ratio reasonable?
Sean
'91 B4C
'92 B4C
'95 B4C
Haha, more B4C's than p.haze92, at least for now
Sean
'91 B4C
'92 B4C
'95 B4C
<font face="Verdana, Arial" size="2">
</font>
</font>
But I still have the stock intake and the engine pulls real hard from 2800 rpms to 5500 rpms! I figure with the aftermarket intake, base and runners, I'll be hitting mid 13.4 to 13.5 traps, maybe a little better.
But remember that is with 2.77 gears!
My times now are in the signature but I could have gotten a tenth lower if I wanted to tune it alittle more.
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
(stock intake, runners and suspension)
13.879 @ 98.90 mph (with 2.77 gears!)
Moderator of http://www.iroczone.com
Member of JFA Crew
I am glad you said 2.77 gears. I would be really disappointed in spending a lot of money to go only mid 13's. My stock 91' 1LE ran 13.90's and most of my B4C's run 14.09 to 14.35 @ 96-100mph. I would like at least low 13's if not high 12's and still be emissions legal here in AZ.
theshackle
Mar 5, 2017 06:37 PM
