dont call me stupid, but i got a ? on how to install an air foil
Old Jul 17, 2001 | 07:30 PM
david foraker's Avatar
ok, i bought this airfoil off a guy on the board and i have the foil, a screw, and a little metal peice with a hole for the screw to go in. what do i do with the metal peice? do i stick it in the TB, the screw the foil in? i tried this but the airfoil sticks out alittle more then it looks like it should. thanks
Old Jul 17, 2001 | 08:04 PM
cobrakiller1989's Avatar
I bought a TPIS airfoil off of a guy and had problems intalling it.(i swapped from 305 TBI to 355 TPI but i cant install an airfoil ) No matter what i did the hole in the arfoil wouldnt line up with hole in the littl metal peice. not even close. I ended up getting mad and getting some good 2 part epoxy and just epoxying it in. It has been in there tight for a few months now and will probably be there for a long time. IM sure if i wanted to get it out i could just pry it out with a screw driver.
Good luck, i hope you dont have to glue yours in
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*NO recent time slips.
Old Jul 17, 2001 | 09:33 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I belieave you remove the plate that says Tuned Port injection. Stick the airfoil in and put the little metal wedge in the top under the plate. I think think the scre goes through the whole in the airfoil and threads into the little metal wedge which you slip in behind it under the TPI plate. Hope this helped
1987 T/A GTA 5.7L, Bored .020 and ported for .202 valves, edelbrock headers, flowmaster exhaust, JET STAGE II chip, Comp CAM, Adjustable fuel pressure, Airfoil, K&N filter, B&M stage 2 shift kit, and a home depot ram air(Hey it looks good and it works)
Old Jul 17, 2001 | 11:05 PM
chiefz28's Avatar
[QUOTE]Originally posted by david foraker:
ok, i bought this airfoil off a guy on the board and i have the foil, a screw, and a little metal peice with a hole for the screw to go in. what do i do with the metal peice? do i stick it in the TB, the screw the foil in? i tried this but the airfoil sticks out alittle more then it looks like it should. thanks[/QUOte
As posted by EDGE that sounds about right . If you run into the same problem as the other guy who had to expoxy his in.I to couldn't get my screw to line up.So a took a drill and elongated my hole bit till it would go.Just in case you can't get ahold get ahold of any expoxy
Old Jul 18, 2001 | 10:15 AM
IROC-Z_85's Avatar
Wow
Now i feel lucky that mine worked so well
(not performance wise)
1985 IROC-Z, nuff said :P
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 13, 2015 08:28 PM
92purpz28
Aug 11, 2015 02:30 PM
bryan623
Aug 10, 2015 11:33 AM
drathaar907
Aug 6, 2015 04:20 PM
