Ram Air Hood Clearance for my Custom Runners
Old Feb 4, 2008 | 02:20 PM
hardcoreZcar's Avatar
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Im building a set of custom siamesed runners from 4 3" U bends (aluminum). The problem is the radius isnt as tight as on the stock tubes. To mount them how i want to, I will need to raise the upper plenum an 1 or 1.5 inches. Will this clear my ram air hood? The engine isnt in my car yet as i am building it still and want to build it before i put it in. How much clearance is there between a stock hood and the top of the plenum. Does anyone think ill have a problem raising the plenum an inch? How much room do u think i can go up with my fiberglass Ram Air II hood? Thanks alot guys! - Ray
Old Feb 4, 2008 | 07:26 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Ram Air Hood Clearance for my Custom Runners
i have the ram air II hood on my 87 formula 350TPI and i believe it gives 2" extra clearance.... the hood is thicker than stock tho. but its a 2" cowl so that would be the diff. i could test it with sum puddy etc if u want over the stock TPI height... but ihave SLP runners and they are shorter than stock
Old Feb 4, 2008 | 07:53 PM
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Wow. Thats awesome. I would be infinitely greatful if u did. My whole engine build is revolving around this bit of info and id hate to do all this work and not be able to close my freshly painted hood. i hear the throttle body is the area thats the closest. Thanks again man!
Old Feb 5, 2008 | 02:01 AM
Car: 87 TA clone
yea i'll do that prob by the weekend. its hard for me with work and class. yea its the throttle body/front of plenum thats the highest point... but usually its the screw/ribbed rubber boot that connects the TB to the intake tube or MAF.... the stock TPI has a downward angle where the TB mounts. the HSR doesnt and thats the prob with that intake and usually why it doenst fit. since urs is still gone be a TPI im not sure wats gona happen. if u raise it the same all the way around then the TB wont be the highest point. with raising it an inch i kno you wont have a problem. goin 1.5-2" and u would need a measurement.
also depends on what engine mount bushings u use.... stockers are rubber but if u go poly its gona raise the motor 1/2" over stock.
Old Feb 5, 2008 | 04:04 PM
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Yea, im going to school, workin and wrenchin so i know what its like. Thanks again bud!
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
bryan623
Aug 10, 2015 11:33 AM
