a/c removal
Old Jul 17, 2001 | 06:37 PM
hello's Avatar
a/c removal
i want to remove my a/c from my car does anybody know if a company makes a pulley that will go in place of the compressor?
Old Jul 17, 2001 | 06:50 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
The part number for the delete pulley is 10055890. I got it for $35 from http://www.gmpartsdirect.com. Some other places sell it for like $50+
Old Jul 18, 2001 | 12:52 AM
hello's Avatar
ok thanks for the info man
Old Jul 18, 2001 | 03:46 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
deleted mine and it's the best mod i ever made good luck trying to find an a/c delete heater box though.i paid a kin nng's ransom to the only guy that had one...disc. by gm
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete.
oh!no!i think my maf is going!!!!!!!!!!!!
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
Old Jul 19, 2001 | 09:41 PM
Car: '89 IROC-Z
I yanked out my AC trying to clean up my engine then I realized it doesn't take up all that much space. The smog crap takes up the most.
Old Jul 19, 2001 | 09:55 PM
86Z28TPI's Avatar
Want to sell your compressor???
Old Jul 19, 2001 | 10:01 PM
leirch's Avatar
Not having AC kicks *** but sucks on those HOT *** days. But if you weigh the good vs. bad I would do it again!
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 20, 2001 | 12:36 PM
82resto's Avatar
To the comment about wanting to sell the AC compressor... i'm taking mine off this weekend... email me if you still want one
Jon
jmnierengart@students.wisc.edu
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
Old Jul 21, 2001 | 09:20 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
I have always wondered why people hack the A/C off thier cars. Anyone care to comment why this is such a "performance" mod? Would it not be smarter to just take off the belt if you are worried about engine drag? This way you would not kill the value of your car.
Old Jul 21, 2001 | 11:16 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
ES87iroc it really isnt a "performance" mod. I am sure that you will probablly free up a little horsepower but nothing so huge that you will notice. I personally dont think that you will be lowering the value of the car beceause I will never sell my car. If you do it right you can always put it back in so you are back to where you started.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
