Whats this peice?
Old Jul 15, 2001 | 05:39 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Whats this peice?
I was putting new vacuum lines on my car when I ended up crushing this little plastic connector valve kinda thing. Now without it my car stalls out at idle.
Its on the passenger side near the distributor. It has 3 vacuum lines going into it. 1st goes back somewhere by the distributor, 2nd goes around to the charcoal canister, and 3rd goes into the back of the plenum. Whats this peice called? Is it hard to find? I've tried everything to bypass it and I've looked around for a new one but I can't find it. ANY ideas would be helpful.
Old Jul 15, 2001 | 06:37 PM
89REDGTA's Avatar
Sounds like it is just a vacuum line Tee. It is used to tee off a few vacuum lines from one source. You could find them at any auto store. Just bring the broken one down to the store and buy a new one.
Old Jul 15, 2001 | 06:53 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
The "piece" you're talking about "is" OR "goes to" the vaccuum solenoid for the EGR valve! Older cars used ported vaccuum source for the EGR valve! Newer, computerized, cars (like yours) use this vaccuum solenoid to run the EGR valve! The ECM sends a signal to the solenoid in pulses, the solenoid in turn sends vaccuum in pulses to the EGR valve! My guess, whatever you crushed is preventing the solenoid from sending proper vaccuum to the EGR valve and this is causing the car to stall out at idle! Hopefully if it's just a "tee" you can fix it.... I know I've broken the line to mine TWICE and just patched it with a piece of rubber hose and some electric tape to provide a better seal for the vaccuum!
Old Jul 15, 2001 | 06:54 PM
Car: '89 IROC-Z
Its not a normal vacuum connector T. It has some sort of valve in it that only allows air to go in certain directions.
Old Jul 15, 2001 | 09:04 PM
Steve87Pont's Avatar
I will venture a guess at Fuel Tank Pressure Control Valve?
"The Fuel Tank Pressure Control Valve is located is located near the cannister and is connected to the fuel tank vapor return line. When the tank pressure exceeds the spring pressure (6.0Kpa)the valve opens. Fuel vapors from the fuel tank are now free to vent to the cannister......".
If I remember correctly mine was mounted on the AC Bracket.
Not sure if this is what you were looking for.
Old Jul 17, 2001 | 02:49 PM
<font face="Verdana, Arial" size="2">Originally posted by Steve87Pont:
"The Fuel Tank Pressure Control Valve is located is located near the cannister and is connected to the fuel tank vapor return line. </font>
He said it was located near the distributor, not the cannister so I ruled out the Fuel Tank Pressure Control Valve!
Old Jul 17, 2001 | 06:14 PM
Car: '89 IROC-Z
It has 3 vacuum lines coming out of it shaped something like this (I think ...its broke into a million peices)
<img src="http://home.earthlink.net/~chris255/valve.jpg"
it has some sort of valve that ony lets air go in one direction. I looked at my friends 91 Z28 and it had the same thing. Before that peice broke one of the vacuum lines going into it broke and made my car do the same thing (stall out unless you leave your foot on a gas) so I cut off the broken part and it started up fine. The next day that hose broke again and when I put a new hose on it I ended up breaking that valve ...nothing has worked yet. I'm hoping I can find that part in a junkyard tomorrow.
[This message has been edited by 88IROC350TPI (edited July 17, 2001).]
Old Jul 17, 2001 | 07:02 PM
Jas89TTA's Avatar
I think you can still get it from the dealer. I think it's listed as a cruise control vacum valve. I have the same thing on my 87 T/A and one of the hoses from the valve runs to a y-tee and splites to the cruise servo the other goes to the cruise vacum tank in the LH fender. I'll check tomorrow at work and see if I can get the part number for you.
350 TPI, 5-spd, 3.73 gears, Posi-Rear, LT4 Hotcam, 1.6 Roller Tip Rockers, Accel Intake, Ported SLP Runners, Ported Stock Plenum, Ported Cast Iron L98 Heads, Coated Hooker Headers, 52mm Edelbrock Throttle Body, 24# SVO Injectors, SLP Cold Air Intake, Holley AFPR, LS1 Aluminum Driveshaft, Flowmaster Exhaust, Taylor Wires, MSD Coil,
Engine pic at http://albums.photopoint.com/j/Album...410&a=13413975
Old Jul 17, 2001 | 08:48 PM
Car: '89 IROC-Z
I was just looking through a Haynes manual and saw a picture of what looks like the same peice. They call it the "vacuum damper valve" In the picture the valve is on the drivers side next to the throttle body. It looks exactly the same but its in a completely different location ...might that be it?
Old Jul 17, 2001 | 09:08 PM
cobrakiller1989's Avatar
I sent you an email. I have one of them that ill give to you. just send me like $2 to ship it and its yours.
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*NO recent time slips.
Old Jul 17, 2001 | 09:15 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Thats a vacuum check valve. It keeps vacuum from bleeding into the intake under accel conditions. It holds vacuum in the checkball under the battery (on fbds) or under the charcoal cannister (camaros). You can get them in the help isle just about anywhere. You probably lost control of the heat/ac vacuum operated doors and stuff.
Old Jul 18, 2001 | 04:25 AM
Omar's Avatar
In addition to what Joel said, it also holds vacuum for the cruise control, if so equipped. You can get that check valve at any auto parts store.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jul 18, 2001 | 08:28 AM
Jas89TTA's Avatar
The part number for the check valve is 14056648 it's about $5.20 from a GM dealer.
Old Jul 18, 2001 | 11:13 AM
Car: '89 IROC-Z
Thank you all for the info. I'm gonna go look around in all the local auto parts stores for that peice one last time. I'll let you know what I find.
Old Jul 18, 2001 | 06:26 PM
Car: '89 IROC-Z
I found a check valve basically like the one I broke so I rigged everything up the way it should and my car still dies at idle. I triple checked all the vacuum lines and there aren't any leaks. Another thing I noticed is that my car knocks like crazy when I gas it going down the road. I checked the timing and its at 6 degrees. I'm clueless ...this is really starting to annoy me
Old Jul 20, 2001 | 12:01 AM
Buy a rustang!
Old Jul 20, 2001 | 01:21 AM
firbird's Avatar
wow, i just broke one of those today! i was trying to get the tube off and one of the ports broke off. Have to look in the parts store for one maybe they have one.
Old Jul 22, 2001 | 06:30 PM
JoelOl75's Avatar
They get kinda brittle with age. So do the EGR soilnoids... I don't know how many of them i snapped the vacuum lines off..
armybyrd
Sep 28, 2023 12:16 AM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
breathment
Oct 12, 2001 12:29 PM
SLAYER6669
Aug 31, 2001 02:37 AM
Bort62
Mar 25, 2001 02:29 PM
