Can 26# injectors be used on a 383 TPI motor?
Old Jul 22, 2001 | 09:31 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
I'm about to purchase some injectors for my 383sb motor & i was wondering if i could use the 26# injectors that Accel sells for about $239? Please check my signature to see if can be done. In the near future I'm planning on buying new AFR 195cc heads, TPIS's Miniram & I want the car to be already equiped with the right injectors; no need to buy injectors twice. How much power do these 26ers support? With my future upgrades heads,intake I'll be looking for some low 12second passes at about 115 - 120 mph. Do u guys think that its possible or should I re-think my plans?
njdaewoo
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
Old Jul 23, 2001 | 11:36 AM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
Since you are planning on AFR 195's and a Miniram, I would suggest some 30# injectors. I bought 30# SVO's for my car and have debating if I should go to some 36# injectors. The AFR's and Miniram will flow a lot more air and since you'll need a custom chip anyway, just get the 30# SVO and be done with it.
87 IROC-Z 305 TPI gears, exhaust, converter
14.70 at 94.1 mph
Solid Roller Minirammed 377 waiting to be installed
mhatfield 14
Oct 24, 2015 07:48 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
