Test Port/Schraeder valve thread size
OK, from searching, I've found that the actual test/schraeder valve is a -4AN fitting. If I remove that ENTIRE valve/fitting altogether, I'd be left with a threaded hole in the fuel rail.
Does anyone know if THAT hole is also -4AN?
....I'm looking to get an adapter for a pressure gauge.
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: Test Port/Schraeder valve thread size
Are you putting a gauge in the car or just on the rail? I just removed the schrader valve itself and left the fitting, then put on a -4AN 90 degree swivel fitting,braided line and -4AN to 1/8NPT adapter for mine.
Gauge on the rail.
I already have the gauge and a 90 elbow, terminating with a female 1/8 NPT fitting. Ideally, a male 1/8NPT (to fit the elbow) to a -4AN female (to go on the test port) would be what I'd get, but I can't seem to find that adapter. I HAVE found several Male to Male adapters with the various threads, hence my need to confirm the fuel rail threads.
Whew! - does that make sense?
Car: 90 Formula
I know Aeroquip makes a -4AN male to 1/8"NPT female adapter since I have one, I don't see why they wouldn't make the opposite. I found mine at a local speed shop. Worse case you may have to change your gauge but I'm pretty sure the fitting into the rail is 1/8"NPT.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the hole is 1/8 NPT female, you can just use a 1/8 NPT to -4 AN adapter.
It shares the same thread size and pitch as -4 AN, but it's not a -4 AN fitting itself.
If I get a male -4AN to male 1/8NPT, I could remove the test port, and all would be merry. I think. -but, as I've learned in other threads (thx apeiron), the AN fittings seal with the 37 degree flared end. If my fuel rail doesn't have an actual AN fitting, but simply the same threads, would it seal?
Thanks for entertaining my learning curve.
LOL, yeah, I think I'm overcomplicating the "seal" issue.
I've got so many different things regarding differents fasteners in my head, different sealants, compounds, tape, threads, dope, AN, NPT!!!!
I think I got it.
I think I got it.
Engine: 383 Carb
Transmission: 4L60
I thought you were talking about using a piece of hose when you mentioned AN to start with...
If you remove the test port, you'll be left with a (probably) 1/8 NPT female hole... then you'd use a 1/8 NPT street elbow, screw it into the rail, and then screw your gauge into that.
Car: 90 Formula
You could just get one of the gauges that screws directly to the rail fitting, remove the schrader valve itself and call it a day. Accel made them in the past.
Car: 90 Formula
Now that you mention it I do seem to recall hearing about them leaking. Sorry for bringing it up.
The hole isnt -4AN. I'll see if I can verify what it is later, but its not AN. There's no seat down in the hole for it to seal to.
.....but if not, I'll be wrenchin' this weekend.
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
I do not know the exact size but it is not tapered pipe thread. it is a straight thread with a o ring seal. a "standard type of fitting" goes in what i do not know.
I removed the internal check valve and had napa match the flair fitting to the 1/8" npt with an adaptor hose. flair on one end and npt on the other.
Guest
Posts: n/a
Little late here, but the thread is a 5/16-18. They used a washer/seal thing between the fitting and rail, its an aluminum washer with a seal cast into the washer. Its possible a metric thread will fit, but the size and spacing indicates a std thread.
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
On a callaway vette. the schraeder valve is removed and replace with an straight adapter piece ( looked store bought cause it was blue anodized). It converted to -4an.
It was needed to run a additional fuel line. Which supplied regulated fuel (FMU) for two added injectors, installed in the boost side, just pior to the Throttle body. Looked like a horizonal TBI.
Also remember 1/8 npt is a tapered thread and the o ring seal stuff is straight.
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Try an auto parts store, look in the air cond stuff, they use the same valve for loading freon.
i used brass on my fuel rail, 1/8 npt to a t-fitting, on one port i put the factory test port schrader valve so that would still be available for manual gauge test at engine, on the other port i installed electric fuel pressure sensor from grand national turbo, that feeds electrical signal to digital gauge on dash. more than 10 years ago and no leaks. also used grand national fuel pump, it flows much better than stock and can keep up with higher fuel pressure.
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
If possible try avoid the Accel gauge for a permanent installation my Accel glass is broken/loose not leaking also another 3rdgen in Swedish comunity had leaks with Accel gauge,so it is a possible security hazard,now on i am only having it when testing the fuel pressure then it goes of the rail.
Only permanent i would recomend is a quality gauge set up with braided line and so on.
regards Mats
regards Mats
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
