Anyone ever done something this bad?
Old Aug 7, 2001 | 10:50 AM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
i believe he's ordering the s/r torquer 305s from World. my question is, how well will this work with the summit cam I have in the car w/ .442" lift. I know the springs handle .560" on the s/r, but won't that be too much spring? Also, i read where the s/r 305s don't flow too great on exhaust? is this gonna kill my purpose for spending 600 on SLP headers? Anyone any ideas on what HP to expect?
Old Aug 7, 2001 | 04:41 PM
CamuMan's Avatar
hey bud, i have those heads, they need porting. they have bigger valve sizes but the ports are near stock. do yourself a favor and have them ported and port matched. i run them with the slp cam 498 lift and have had no problems yet. car runs a decent high 13. but if you really want to go fast, scrap the 305 and biuld a 350. i learned the hard way.
Old Aug 7, 2001 | 05:13 PM
ImportsRsloths's Avatar
Supercharged 334 strokers (basically a 305) are a ton better than supercharged 350's!
Old Aug 7, 2001 | 07:37 PM
Fastcamaro87's Avatar
importsrsloths : for the cost of machine work to build a 334 why not build a 383 now tell me that a supercharged 334 will outrun a supercharged 383 ...haha
and btw what does that have to do with this post anyway??
87 IROC-z 305 TPI 5spd 10-bolt 3.73 posi ,8.8 Accel wires , bosch platinum +4 plugs,MAF sensor screens removed, gutted air box, ram air, K&N air filters,TB coolant bypass ,polyurethane tranny and torque arm mounts, K&N oil filter,Mobil 1 synthetic oil 20w50, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Aug 7, 2001 | 07:53 PM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
forgot the rest of the story...
I tried doing headers... SLP 1 5/8" on my 86 LB9 last weekend. A bolt on the driver side broke off in the head. tried drilling, got an easy-out on it, wouldn't budge. I let my dad work on it since he usually seems to be able to tackle anything... few hours later, "oh f*ck" he says. I walk over to the car, coolant is leaking out of the head. So, we have a problem. He said it's his mistake, he'll make it right.
Old Aug 8, 2001 | 12:11 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I wouldn't worry about the springs. It's better to have too much spring than too little. Just be sure to follow the break in procedure and put plenty of the black moly stuff on the cam lobes and lifters. And put assembly lube or motor oil on the bearings.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
