best method\chemical for rad flush
Old Aug 8, 2001 | 08:12 AM
Going Slow Sucks's Avatar
My rad seams to have been over looked by the last owner.And now it does't seam to flow or cool very well.If any one know's of a good method of cleaning the sludge out, or a chemical soultion could you help me out. I would like to clean the water jackets in the block.
thanks
88 Camaro IROC-Z
350TPI
K&N filter , High flow exgaust (no cat's), automatic tran's shift kit
Old Aug 8, 2001 | 08:56 AM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I used the Prestone rad flush from the local auto store, but used several cans at once instead of one, and also left it in full a full day of driving instead of just the recommended 10 mins. I did this about 4 times with my '79 TA and it cleaned it up fairly well. It was like rust colored mud to start with is how bad it was!
Keep cleaning until you can drive a few hundred miles without it discoloring.
If you have a manual fan, you might check/replace the fan clutch also if it gets warm while idling in traffic then cools down once you get moving. They can go bad and not make any abnormal noise.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
79 TA 6.6l - all original stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, 12.40 @ 108 w/1.79 60'
95 Trans Am Conv.- LT1
[This message has been edited by 2QUIK6 (edited August 08, 2001).]
Old Aug 8, 2001 | 05:05 PM
Bjase's Avatar
Car: 88 IROC
I've used Prestone before with good results, until I tried it in my 88 IROC. After flushing the coolant, my fan switch quit, my coolant temp sensor quit, and my CSI sensor quit. I think my thermostat may have stuck during the flush, causing an overheat. At any rate, be careful!
Old Aug 8, 2001 | 08:44 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I took mine out (82 6.2 liter diesel Blazer) and layed it down with a 2X4 under one end. I can't remember the name of the stuff but you can get it a the grocery store. It is in a flat, green plastic bottle and it's used for removing rust and water scale from sinks, counter tops, etc. Don't get it on you. Pour 3 or 4 bottles in your radiator and every 30 minutes or so put the 2X4 under the other end the stuff runs back and forth through the radiator. Worked great for me.
Z's r Best
Old Aug 8, 2001 | 09:25 PM
82z's Avatar
82z
We use Prestone Super flush at work all the time with good results. However it only seems to work well with properly maintained systems. If your system is pretty grungy then spring for the bigger bottle of the Prestone stuff. I can't remeber the name but I think it is just a bigger bottle of super flush.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
mfp189
Sep 27, 2015 09:25 AM
Stryker412
Sep 20, 2015 06:59 PM
84redta
Sep 19, 2015 09:58 AM
