Cold start injector
Old Aug 9, 2001 | 09:38 PM
9177's Avatar
Cold start injector
I have an 87 IROC that came with a 305i am putting an 89 iroc 305 in complete with intake. Will i have any trouble using the 87 prom without the the cold start injector? also which intake is better?
Old Aug 9, 2001 | 10:21 PM
Vader's Avatar
You may have some difficulty with cold starting (below 70°F coolant temperature). The '89 PROM is designed to enrich fuel pulses of the eight service injectors to compensate when cold, and doesn't need the cold start injector. If you can use the '89 PROM, you might be better off. The only problem may be the VATS system on the '89. You could also have a custom PROM burned to provide cold starting help without the VATS.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
