Crap, just had Accel injectors installed!
Old Aug 6, 2001 | 06:19 PM
Steve00YZF's Avatar
My parents just had their mechanic install the 24# Accel injectors into my old IROC. The mechanic is now saying that the SES light is on, and that they now need a new Mass Airflow Sensor. Isn't the MAF that is in the car the same thing? It had no problem before anything was done to the car, why should it be different now?
Old Aug 6, 2001 | 06:29 PM
JETHROIROC's Avatar
Probably just running too rich with the Accel #24. Is it a 350 or 305? Did you have an adjustable fuel pressure regulator installed to lower it some? What exact trouble code is the ECM giving you? I would sure as hell look into that more, since the MAF is expensive.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Aug 6, 2001 | 06:32 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Yeah, what is the code? He might have just forgot to plug in the MAF or MAT sensor upon reinstallation of the plenum.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Aug 6, 2001 | 06:35 PM
Steve00YZF's Avatar
It's an 89 350. No adjustable fuel pressure regulator that I know of on the car. I don't know the code yet. I asked my parents to call the mechanic and find out what he's getting exactly. I would do it myself, except I now live in AZ, and they're in IL. I would definately hope that they don't have to replace the MAF, I know how much they cost.
Where can I snag an adjustable fuel pressure regulator if I need one?
[This message has been edited by Steve00YZF (edited August 06, 2001).]
Old Aug 6, 2001 | 11:26 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
Injectors don't make the maf go bad. Either he dropped it or is just trying to screw you (assuming it didn't have any problems before the injectors were put in). I'd recommend the holley afpr since you can adjust it by hand, however I don't know if I'd want this mechanic adjusting crap on my car.
good luck,
Dan
87 IROC-Z, 6.7 $uperram & cam, Eagle 5.7" rods, Dart 200cc Iron Eagle heads, auto w/ BTE 3000stall lockup, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" headers, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback.
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear - FOR SALE
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N - SOLD
Old Aug 7, 2001 | 10:17 AM
Steve00YZF's Avatar
It is indeed code 33. The mechanic insists that nothing happened to the MAF, and that it needs to be replaced. Since I'm not working on the car, and my parents don't work on cars, I think they are just going to bite the bullet and get a new MAF. Where can I get one online for a good price? Mechanic wants $500 for a new one.
Old Aug 7, 2001 | 10:52 AM
ONEFINE8T9's Avatar
lol woah, a new maf should cost about 140$ and takes like 5 minuntes to install, better loook into a new mechanic or a chiltons
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Aug 7, 2001 | 11:37 AM
Drakar's Avatar
Your mech is a freak for $500 american I could buy one hear and fly down and do it myself. But it probably is running rich, which will through that code.
1989 GTA 350 TPI
Stock:
- T-tops
- Dual cats
- 9-Bolt 7.75" Rearend
- 3.27 gears
Mods:
- Dynomax Super Turbo Muffler
1992 RS 305 TBI - Sold
Old Aug 7, 2001 | 02:03 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
The first thing to do is check the connections and their condition. I had one of the ports of my maf connector that was not making good contact and it would throw a code 33, I just bent the little contact sockets back into shape and it was fine. $500 - wow, once again hard proof that crack does not just smoke itself. I bet if they go for it they will still have a problem. All too often mechanics say your MAF is bad when it is really something else, he is just reading a code and hoping that it's right. The MAF code is for any error in the MAF circuit, not just the sensor.
Old Aug 7, 2001 | 03:41 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
LOL. $500 For A MAF. LMAO.
88' IROC-Z, 350 TPI, 700-R4
Old Aug 7, 2001 | 03:46 PM
rezinn's Avatar
Sorry guys, thats how much a new MAF costs from AC Delco. The $140 one is remanufactured.
Old Aug 7, 2001 | 03:50 PM
Steve00YZF's Avatar
Where can I get the remanufactured one?
Old Aug 7, 2001 | 11:54 PM
irocz's Avatar
Car: '87 IROC-Z
Every parts store in the country sells reman MAFs. The one to get is the Wells MAF (so everyone says) b/c it's supposed to flow better and last longer. The car should still run in limp mode even if it is bad. Just tell your parents to go get it and bring it home then when you get back you can change it out yourself in about 10 min. (assuming it is actually bad).
Old Aug 8, 2001 | 12:06 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Delco MAF's are easily $500. Don't you need a new engine calibration (chip) going from 19lb or 22lb, to 24lb ?
92Z28
89GTA
Old Aug 8, 2001 | 01:15 AM
Ski89Z28's Avatar
Man, your getting Screwed Without a Kiss, or at least your praents are!
First on the Q-T get you parents to go and pay him right away and try to drive the car or if the guy really screwed you and did some damage then get it home by tow truck. But don't leave it there a miniute longer! If the guy says it is undriveable have your Dad at least try to start it and if it sounds ok then drive it home but don't let the mechanic alone with it, have your Dad follw him.
Like someone else said it should be able to drive home in "limp" mode.
Sounds like the guy wants to make $500 buck to me.
Second if the MAF is bad then do a search in this forum and the Aftermarket forum for WELLS MAF, There should be a site or place to buy one.
Third never go to that mechanic again!!!
Good Luck!
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
(stock intake, runners and suspension)
13.879 @ 98.90 mph (with 2.77 gears!)
Moderator of http://www.iroczone.com
Old Aug 9, 2001 | 12:24 PM
Damon's Avatar
I agree with Ski. Sounds like a classic screw-job to me.
Old Aug 9, 2001 | 04:12 PM
85transamtpi's Avatar
Sounds to me like somebody had some slippery hands when he/she was removing certain parts on your car. I cant see how this would happen, but I have had some experience with shops like that. Once I took my t/a to a trans shop because their freshly rebuilt trans was leaking, and the engine fan magicly stopped working. He called me and said they would be happy to take care of it. I said screw you and picked up a replacement and put installed it in their parking lot durring the middle of the day. Some people just shouldnt be working on cars
peace
Old Aug 9, 2001 | 08:45 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
<font face="Verdana, Arial" size="2">Originally posted by Steve00YZF:
Where can I get the remanufactured one?</font>
Yep, but I bet you the mechanic is NOT going to put in a new Delco! That's pretty much guarunteed.
Old Aug 9, 2001 | 10:55 PM
dgreene's Avatar
Car: 87 Formula 350
Transmission: 7004R
$500?!? I bought one a year ago and it wasn't but $125. I did have a friend that worked at a local dealership get it for me at cost. I figured that retail it would be around 250. Man, that is one helluva mark up!!
dgreene
'87 Firebird Formula 350 TPI, Ported Plenum, Adj. Fuel reg, gutted cat, catback exhaust, air foil, K&N air filter, chip,170 thermostat,Borg Warner Posi 9 Bolt w/ 3.23 gears....soon to be making custom chips for this and my 87' GN
Old Aug 10, 2001 | 12:11 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You may have your problem taken care of by now, but I'd like to point out a few things.
The MAF you get from GM is a Bosch, packaged in a Delco box, with a Delco number.
Last year, GM retail was $411.00, I had a friend of a friend who got me a decent price on one from the dealer for 249.00 plus tax.
As others said, rebuild and others are available, shop around.
Also, TPIS sells NEW Bosch MAFs (or did last year when I was shopping) for 269.00, if I recall, maybe $249.00, un modified.
Now to your problem, it'd be kinda hard to drop the MAF, since it's firmly attached to the aircleaner..kinda makes it hard just to roll off the car that way, but I guess it's possible.
I'd do two things, check the electrical connections on the underside of the MAF and also check the tube between the MAF and the TB, make sure it isn't split, and make sure he has reconnected it to the MAF and the TB properly.
As others have said, no matter what you do, take the car away...if the MAF is bad causing an issue, just unplug it and drive it home, she'll run fine enough, then do some MAF shopping.
Good luck.
1992rs/ss
Jan 31, 2025 05:10 PM
9192camaro
16
Feb 3, 2019 12:21 AM
tazs2000
Jul 15, 2017 08:44 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
