Rocker arm questions
Old Mar 1, 2008 | 02:19 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I would like to know if these will work with my ZZZ 350/ XFI HR13/ AFR 180's.
http://store.summitracing.com/partde...w=32&N=700+115
Thanks fellas, don't want to purchase the wrong ones.
Will
Old Mar 2, 2008 | 02:15 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: Rocker arm questions
Will
Which ZZ block? you stated ZZZ.
Old Mar 2, 2008 | 09:50 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Why wouldnt they? If you have the afr's then you have guideplates. Only concern would be Piston to valve clearance with the xfi's agressive lift. BTW you can purchase any 1.5 or 1.6 rocker non sa with your setup.
I'm still confused. Is ther ea reason you dont think they will work?
Old Mar 2, 2008 | 11:34 AM
norcalz28's Avatar
The main reason is there were a lot of part numbers on the summit site and I got a little confused. I know guys run these with XFI cams, I have never done a build and I wanted to make sure these would be ok.
The motor is the ZZZ motor, grandad to the ZZ1-ZZ4. The first of the GMPP crate motors of the late 80's. I found one new a year or so ago and bought it, the guy claimed it was a ZZ4, but the cam, heads, intake, and block number all point to ZZZ.
Old Mar 2, 2008 | 01:14 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I didn't see a ratio listed....I must have missed it. Anyway, I believe in one of your earlier posts (norcalz28) you said you were going to run the XFI268 cam.I am running the XFI268 with 1.6:1 rocker arms on a stock ('cept the cam) L98 short block, with no problems. My cam is installed on a 107* intake centerline. -Bill
Old Mar 2, 2008 | 04:53 PM
norcalz28's Avatar
thanks for the info guys
Old Mar 2, 2008 | 07:31 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yup. You need the 1.6's as thats what the cam specs include.
Old Mar 2, 2008 | 08:45 PM
norcalz28's Avatar
werd
Old Mar 4, 2008 | 12:18 AM
norcalz28's Avatar
Another question is the springs I am running on my AFR heads are upgraded to handle up to .600 lift. They are 1.530 OD springs, and the summit specs say that the comp pro mags will accept up to 1.500 springs. Is this going to be a problem? Has anyone run a spring this size with comp pro mags sucessfully? Should I consider something like these Lunati rockers?
http://store.summitracing.com/partde...N&autoview=sku
Any help would be appreciated fellas
Will
Old Mar 4, 2008 | 09:08 AM
Sprayed92's Avatar
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
Should be fine as those are a double spring the comp pro mags would be the one's I'd use as they have the most clearance of almost any rocker on the market anyways. If anything you will either have to clearance the rockers a little bit or buy new springs.
Old Mar 4, 2008 | 11:05 AM
norcalz28's Avatar
The lunatis are clearanced to 1.550, which is why I wanted to go with them. I'd have no problem modifying them, but I don't want to buy new springs.
Will
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
