Timing ?'s
Old Aug 11, 2001 | 04:25 PM
Iroc Detroit's Avatar
Timing ?'s
When I set my Timing to specs my car runs really rough. And when I set it by ear its not even near the marks. What could cause this distibutor,timing chain???? Also my car likes to rev high before shifts then when it does shift it squells the tires a little. Any suggestions would help.
1985 Camaro Iroc Z
305 Tuned Port Injected
Planning for a 350 swap soon!!!
Old Aug 11, 2001 | 05:57 PM
mckenzie's Avatar
Hello, did you disconnect the timing connector(tan/black) on the pass. side firewall when setting the timing? best of luck, tom
86 iroc 305tpi auto. mild cam
Old Aug 13, 2001 | 02:04 PM
Yes I disconnected that wire does anyone know how to tell if computer went bad or how to tell if your in limp home mode?
1985 Camaro Iroc Z
Old Aug 14, 2001 | 04:16 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Your marks on the balancer may be off. Try setting it by ear, but don't go too far. It would help if you had a scanner to see if you're getting knock counts.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
