LB9 & L98 difference??
Old Mar 3, 2008 | 04:19 PM
jeepboy180's Avatar
Car: 92' RS 25Th Anniversary
Engine: 305ci TBI
Axle/Gears: 10 bolt limited slip.
Is the only difference the block size????
Old Mar 3, 2008 | 04:49 PM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Re: LB9 & L98 difference??
Hey jeepboy180, the difference is really not the "block" size - the difference
is in the cylinder bore diameter of the block.If I'm not mistaken,the LB9 cylinder bore diameter is 3.723 inches making this a 305ci mill.The L98 has a cylinder bore diameter of 4.00 inches making this a 350ci mill. Hope this helps you out.
" The secret of life is honesty and fair dealing...
If you can fake that, you've got it made. "
Groucho Marx
Old Mar 3, 2008 | 04:58 PM
jeepboy180's Avatar
Engine: 305ci TBI
alright, thank you. I was just wondering if their was a difference in anything else? Such as the heads, Ecm, etc. Because I'd like to go from TBI to TPI. I was just wondering how far the range of availability on the parts went.
Old Mar 3, 2008 | 05:58 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
The heads have smaller chambers and valves also.
Most everything else is the same.
Old Mar 4, 2008 | 01:06 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The TPI intake itself is identical. The block has different pistons and rods, and cylinder heads.
Old Mar 4, 2008 | 06:45 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
The ECM is the same unit, but the actual .bin (tune) is different.
Old Mar 5, 2008 | 04:37 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Knock sensor is differant.
db057
Apr 28, 2019 07:45 AM
BAMiller
Sep 14, 2015 06:38 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Formula_88AE
Sep 3, 2015 01:47 PM
greenyone
Sep 2, 2015 03:39 PM
