??QUARTER MILE??
Old Aug 14, 2001 | 11:22 PM
darbster's Avatar
??QUARTER MILE??
Hey TPI guys,
Heres a question for you....
What do you estimate a "fresh" 20,000 mile 350 TPI engine would run stock with K&N air filter, no cat, and 40 series flows and no other mods? I have converted from 305 TBI and am curious to hear what youy guys think this bad boy'll do before i get started saving for mods.....And yea i will keep in mind that this is an estimate...and oh yea...its powering a freshly rebuilt 700R4.Thanks for the help
Old Aug 15, 2001 | 02:31 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Mid to low 14's.
j.wolfe
_ ____ _
91 GTA L98
Best time: 14.389@95.49 (VMP)
"...Deception..." Brandon Sloan * ...wounds heal and chics dig scars...
Old Aug 15, 2001 | 06:43 AM
darbster's Avatar
sounds like a good place to start for me
Old Aug 15, 2001 | 09:37 AM
IROCKER's Avatar
I say mid to high 14's...with little mods, low 14's would be a bit of a stretch.
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for front and rear LCAs and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, DynoMax 3" Mandrel-bent pipes, Flowmaster muffler, 3" chrome tailpipes, Corvette Servo, TransGo Shift Kit, Corvette 2000 Stall, TruCool LPD tranny cooler, T-tops, and White exterior with red leather interior.
2001 Sunfire GT
Bone stock 2.4L, 5-speed, K&N cone filter, interior detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
3rd Place Stock Class at annual 2001 JCO Bash
Web: http://www.angelfire.com/on3/whitelightening
Old Aug 15, 2001 | 02:21 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
high 14s to 15.0 for '85 to '88.
mid to high 14s for '89 thru '92.
IMHO
A friend of mine took his stock '88 350 IROCZ to the track last month and ran 15.2sec. This track is well known to be slow, about 0.3sec.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 3000 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, 24#/hr SVO injectors, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(40psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.27sec @ 103mph on MT ET Streets
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Aug 16, 2001 | 12:01 AM
rudys119's Avatar
well i have a 87 350TPI with bout 120,000 as far as mods i ported the plenum, added a stage III chip and cut out the cat, stock exhaust and stock headers for now, and i ran 14.2. (that was on bad tires and me peelin out bad at the beginning)
87 GTA 350 TPI
Mods: K&N Air Filter, New rocker arms, Stage III chip.
Next Mods in line: Exhaust, headers
http://www.geocities.com/rudys120/transam.html
Kills:
Nissa 300zx (dont think it was turbo)
87 Mustang 5.0,
89 Mustang 5.0 (modded)
?? Iroc
00-01? Jaguar driven buy 85 yr old guy
Too many ricers to count......
deracer
Apr 11, 2016 12:04 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Exxon Limited
Aug 9, 2015 08:13 PM
