valve spring/exhaust question
Old Mar 8, 2008 | 06:31 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
If i put in an exhaust cutout for the occasional trip to the track, will i have to worry about having enough backpressure for the exhaust valves to function correctly? the engine has only around 20k (acdelco reman). i have been told (not sure if its accurate) that the factory springs require a certain level of back pressure to return to the closed position.
thanks,
Jason
Old Mar 9, 2008 | 08:16 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: valve spring/exhaust question
You'll be fine, dont worry about that.
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
