IAC going bad?
Old Mar 10, 2008 | 10:37 PM
cwyates4's Avatar
Car: 85 vette/87 TA
Engine: built 383/350 tpi
Transmission: built 700r4s
Axle/Gears: 3.45 dana 44/ 3.27 9 bolt
IAC going bad?
I have this intermittent idle problem on my car now (85 vette). Most of the time, it cranks and runs fine, but sometimes it will not run without my foot on the gas. I had the IAC cleaned and throttle body, but it hasn't completely went away. For a temporary fix, I turned the idle screw up so it will idle when the IAC doesn't seem to work, which has become more often. When it does decide to work though, the car idles really high, so I have to turn the idle screw back down, or spin the tires shifting into gear and idling at 50mph!
So is the IAC just going out? I already have a new one, and install seems simple, but could there be something else wrong? Car runs perfect otherwise!
Old Mar 11, 2008 | 06:21 AM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: IAC going bad?
replace it,later jimmy
Old Mar 11, 2008 | 12:18 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: IAC going bad?
replace the iac and do the specific tuning instructions and re-set your TPS voltage. the tps sensor has to read .54volts. when you messed with the idle screw you messed with the voltage reading on the tps
go to tech articles on this site and it will tell you what to do.
also wouldnt be a bad idea to check your spark plugs check MAF sensor and replace your fuel filter which is like 15bucks
Old Mar 12, 2008 | 01:08 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: IAC going bad?
Look for vacuum leaks at the Throttle body and check for cracked plastic lines. High idle speed means more air. Could be air leak or iac. What are the iac counts doing. more counts, more air, less counts less.
92firebirdguy
Sep 1, 2016 07:53 AM
earlpote
Sep 12, 2015 11:55 AM
pacoelrapido
Sep 11, 2015 02:41 PM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
