FP problems
Old Aug 29, 2001 | 07:53 AM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
FP problems
K, well i hooked up a Pressure tester to my schrader valve and when the pump primes i get 25 PSI. I know this aint right but i just had the pump replaced, it also whines really really bad. Just replaced the filter so should i take a look @ the lines and see if they are restricted anywhere?. Also after the pump was replaced my fuel gauge shoots up past Full. Now you guys are gonna flame me but i got the work done at Pep Boys (not by choice). Its past warranty now, do you think i should go back and raise some hell or just go and do the work myself and just say frig it?
Old Aug 29, 2001 | 10:34 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If it's out of warranty, save your time and frustration.
It's been but a guage that goes full is either a shorted or open wire...either way, most likely was done when they installed the pump..not sure of you can see it with the tank in though.
A whining pump isn't good, most whine some, but not obnoxiously. Does the pressure go up with the engine running?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
