Best cam for Mini Ram?
Old Aug 30, 2001 | 11:34 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
What do you think. I only think I will shift at 6000rpm.
Mods: ZZ4 engine w/stock TPI, adj, fuel pres. reg., MSD 8.5, HI6S ign. w/ PS-91 coil, K&N filter, TPI air foil, Hooker comp. shorties, American Thunder flows. 160* stat., TB bypass, 3"cowl, bat. relocate, AC delete, stock T-5 w/ 3.42 rear, ported plenum
Old Aug 30, 2001 | 10:24 PM
FlashGTA
Guest
Posts: n/a
Call TPIS it's their Intake and they can give you the best advice. But otherwise I would go for the LT4 Hot Cam. It is designed for the LT4 which was patterned after the original mini-ram.
Old Aug 31, 2001 | 11:40 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Thats what I was thinking. Thanks. I will also do 1.6RR when I do the intake and cam. Does anyone know about how much power that will add? Horsepower or seconds ( -0.2,0.7)?
Stangski09
Nov 14, 2015 01:27 PM
Jorlain
Oct 8, 2015 01:57 AM
64goatman
Sep 9, 2015 01:09 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
