heads on a 305
Old Aug 29, 2001 | 10:32 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
heads on a 305
what do u guys think, the aluminum corvette L98 heads with a good port job..... or the new world products torquer heads?.... please help i need info thanks
305, TPI,compucam 2030 cam, air foil, 8.8 wires, accel super coil, dynomax headers, custom y-pipe, cut out, 80 series flowmaster, 2.73's and an open diff(3.42-3.73 on the way). and a stage 4 chip :0). hittin a sad 15.2 before the chip.
Old Aug 30, 2001 | 03:53 AM
BenDoe's Avatar
I have heard the vette L98 aluminum heads are really good on the 305 because they have the same CC combustion chanber as the 305 heads(58cc) and respond very well to a small porting job. I happen to have a set I would sell for $400 plus shipping. Other people get the torquer 305 heads you suggested, but i think those can get pricy compared to vette heads that will probably be better.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218, 187 head castings with bigger valves, self-burned eproms.
All work done by myself, and proud of it!
SOON TO COME 327 Miniram (3/2002) PARTS NEEDED:Titanium valvetrain parts, stud girdles, fluidampnr, miniram, bulletproof bellhousing, MONEY(im in college).
Find a .bin on the internet and want it burned? I'll do it for you!
Old Aug 30, 2001 | 07:43 AM
86IROCTHD's Avatar
Car: 88 Trans Am
cool is there anything wrong with the heads. cause i might just get them and put them on a 355 small block with 6 inch rods and a zz9 cam. should get me in the 12's with 3.42 gears :0)
Old Aug 30, 2001 | 07:47 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
a little info on the vette and W/P heads
the stock vette heads have a
58cc cumbustion chamber
1.94,1.50 valves
160cc intake runners
World Product heads have
1.94,1.50 valves
170cc intake runners
the W/P heads also come with a duel pattern for the valve covers
i bought my W/P heads for less than $700 complete from CincySpeed Warehouse here in Cincy
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Aug 31, 2001 | 04:43 AM
BenDoe's Avatar
Nothing wrong with them that i know of. I pulled them off a motor that i have in my garage, i was going to use them, but decided to go with canfields after long thoughts. You might wanna have them rebuilt though, and while their at it, have a extra hundred in porting done. Then you'll flow more than the iron world products heads, and have aluminum for about the same price. Email me if your intersted.
Old Aug 31, 2001 | 07:13 AM
CamuMan's Avatar
i went with the world heads and had them ported. thru some roller rockers on them and they work great. never had the car at the track but i took a 98 cobra pretty easily and he ran a 14.0 flat at 100. i was crapping my pants as i pulled on him!!!
Old Aug 31, 2001 | 04:47 PM
BenDoe's Avatar
ya, but remember this guy has a 305, but i bet he could still do a low low 14 with either of the heads and his gear change. Its just a matter of iron or aluminum...
Old Sep 1, 2001 | 01:41 AM
86IROCTHD's Avatar
Car: 88 Trans Am
yea i think i can do low 14's like 14.1 or 14.2 with the gears and the setup i have now, but i would need slicks and it would have to hook up at the track. thats a big problem for me even with 2.73's. but if i go ahead and get the other motor...... F*&% 14.s i will be hittin 12's and shootin for 11's...... so..
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
