Why do I have oil in my Intake?
Old Sep 2, 2001 | 08:31 PM
90FormulaL98's Avatar
Car: 1990 Formula 350
Engine: L98 350
I have the stock valve covers and they are leaking around the oil cap and pcv valve oil all over the cover. Also oil is going from the breather tube that runs from the throttle body to the valve cover. I have oil coating the whole inside of the intake. Do I need to get valve covers with baffles?
Thanks, Gary
1990 Formula 350
13.8 @ 98 MPH 1/4
Old Sep 2, 2001 | 08:37 PM
JETHROIROC's Avatar
The stock covers DO have baffles...sounds like you have excessive blowby to me. How many miles on the engine? Check the PCV valve as well, but with oil in the intake it probably works.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 2, 2001 | 10:10 PM
Engine: L98 350
It has 150,000 miles. So what does the blow by mean?
Old Sep 2, 2001 | 10:15 PM
JETHROIROC's Avatar
Either your rings or valve guides are excessively worn allowing combustion gases to create excess crankcase pressures. Does the car use much oil? I would do a compression check on it and then repost the #s for us so we can help decide what it is. The 350 might be due a rebuild, although from your sig. it runs well. Hope this helps.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
