What fuel pump do i buy
Old Mar 20, 2008 | 10:43 PM
RGV 89 GTA's Avatar
Car: 2001 SS/1989 GTA
Is this fuel pressure gauge reading normal
I have a fuel gauge and it shows fuel pressure drop shortly after I rev it and hold it there. Seems to me the pump is not sending enough fuel or can something be wrong with the bbk adjustable fpr. Car is a 89 gta tpi that has the sdpc vortec crate engine that is rated at 360hp , car has all the bolt ons with 24# inj at 50 psi. What pump is good or how many lph do i need. *************( I Have since put in a walbro pump and racetronics hotwire kit.same thing happening.)******
Last edited by RGV 89 GTA; Nov 29, 2009 at 04:27 PM. Reason: forgot to include some info
Old Mar 21, 2008 | 07:40 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: What fuel pump do i buy
Change the fuel filter first.
Then check out racetronix.com They have some good info even if you don't buy their pump.
Old Mar 21, 2008 | 11:08 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Can't go wrong with a true Walbro 255lph pump. Even the HV version wouldn't hurt.
Old Mar 21, 2008 | 12:48 PM
RGV 89 GTA's Avatar
Thanks pandin, I feel stupid for not thinking of that.
Old Mar 21, 2008 | 02:38 PM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
Don't feel bad, had a fuel issue with mine and it wasn't the fuel pump, fuel pressure regulator. new injectors, increased the wiring guage to the pump, and cleaned out the fuel lines. None of these solved the problem. Turned otu the ecm isn't up to the task. hope this wasn't your problem. my motor would have bene good for around 400hp or so.
Old Mar 21, 2008 | 07:27 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I make 470 horse and have a holley 255lph fuel pump with no problems.
Old Mar 22, 2008 | 06:50 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
If you had just changed it, should I feel stupid for suggesting it?
It follows the 2 foot dummy rule. Anybody working on something (within 2') will miss the "obvious", anybody else won't. If you trade places, the, 2' dummy, person changes. It does not matter who is closest. They will always be the "2 foot dummy".
DAMHIKT.
Old Mar 22, 2008 | 09:14 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Get the racetronix kit with the walbro pump.
Old May 15, 2008 | 03:36 PM
RGV 89 GTA's Avatar
well i changed the fuel filter and it the same. and since then i just put a walbro fuel pump along with the wiring upgrade kit and it stayed the same, I haven't changed the fuel pressure though, should I raise it? last time i did it wouldnt idle right ,its at around 45 psi now. Or maybe its normal for the gauge to do this or its not working.The car still runs ok but i cant tell if it improved because the trans slips.the tranny is last on the list to replace with a t56 since its a big project.
Old Nov 29, 2009 | 04:08 PM
RGV 89 GTA's Avatar
wow been a long time since i messed with this car. still does the same thing but have always wondered if its normal. again I have a fuel pressure gauge with like 2 1/2 feet of hose connected to the shrader valve and like before if i rev the engine and hold the throttle the pressure drops.Is this normal? runs ok.
Old Nov 29, 2009 | 04:31 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
What does it drop too?
Old Nov 29, 2009 | 04:51 PM
RGV 89 GTA's Avatar
from 45psi it goes to about 30-35psi and then goes back up when throttle is released.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
