Anybody got autometer 100 psi electric FP guage??
Old Sep 7, 2001 | 08:57 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Went to the speed shop down the street last night and was looking to get a autometer A/F guage and a single pod. I saw this 100 psi electric fuel pressure guage in the catalog there and was considering it along with the 2 guage pod.
Anybody put one of these in yet??? There's an adapter fitting in the back of the catalog that'll supposedly screw in the fuel rail if you unscrew the schraeder valve BUT I don't know how big the sender unit is... Is it a big ugly POS that'll require some more adapters?
I really don't want to mess with a mechanical guage and it's isolators to mount it inside and taping my homemade guage to the windshield is a big PITA.
Opinions???
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.70 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Sep 7, 2001 | 09:27 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have the 2 gauge a-pillar mounted pod with the A/F ratio meter and the electric fuel pressure meter. Good combo. The install is straight forward and the the sender is about the size of pear. Not to noticeable if mounted correctly.
Old Sep 7, 2001 | 10:22 AM
Car: '89 Formula
Engine: 355 TPI
Thanks.. Did you need any other fittings to get it neat looking??? Will I need that adapter or will this sender go in where the schrader valve is now???
Yeah, I was looking at the pillar pod... shoulda said that.
Old Sep 7, 2001 | 12:53 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Got any pics?
I'm gonna be using one of those along with an A/F ratio gage and a nitrous pressure gage. I think it'll look kinda cool...
I was worried about the sender being the size of a pear. I just wanna know how to hide it.
Old Sep 7, 2001 | 04:03 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I have an autometer phantom e fuel pressure guage in my car, i flush mounted it in the dash where the cig. lighter was.
Install is straight forward. You decore the schrader valve. Then you adapt the 1.4 male flare of the valve with the 1/8 npt inlet of the sender. I have my sender UNDERNEATH my plenum, i did this by simpy bending a 1/4 brass tube in a 270' loop and pointing it out under the plenum. It's about as tight as you can effectively form a 1/4 tube, but you can clear the MAP/plenum by doing it this way. That ends into a 1/4 flare male to male, then i got a 1/4 flare female to 1/8 ntp femal to hook to the sender. I bought all the fittings at home depot.
The sender then runs to a small control box, i mounted that out of the way under the kickpanel in the car. The control box is maybe 1/2" deep and maybe a little less than 3x3".
Here's a tip, hook up the switched power wire for the guage to the accessory circuit rather than the ignition circuit. Subtle difference, with the guage on the ACC ckt you can turn the key backwards and observe your FP leakdown w/o priming the FP and ruining your observations. The drawback is you can't see the FP when cranking, but this is trivial, since if you have FP before you start cranking, it isn't going to dissapear when you start cranking, the injectors pulsing to start it aren't gonna eat that much pressure off it. I'd rather be able to check leakdown personally.
I have a few pics of the install at home. They're not great but they might give you a better idea of what i mean by the sender under the plenum, drop me an email at ed@thirdgen.org if you want me to send them to you.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
LB9 A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Sep 7, 2001 | 07:50 PM
u r sofa king we tah did's Avatar
if you have a wet nitrous system hooked up to the schrader valve, is there any way to split the valve into 2 to use the nos fuel solenoid and the gauge sending unit?
Old Sep 8, 2001 | 03:26 AM
Omar's Avatar
Yes, you can buy Brass "T" fittings to make multiple connections.
Also, keep in mind that autometer makes a full electric sweep gauge for about $180, and a cheaper half sweep for about $80.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
[This message has been edited by Omar (edited September 08, 2001).]
Old Sep 8, 2001 | 01:28 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Do you have p/n for both different gauges?
Thanks!
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
