just got car DYNOED but need more power!!!
Old Sep 10, 2001 | 12:25 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
ok guys i had a whoping 193.7@4450 hp and 270.2 ftlbs of torque at@3200 rpm. i have a 305 with stock heads and stock intake tpi what else do i need? please help. mods are as follows bored .040 over, compucam 2030 cam, .423/.446 lift stock heads, coil, wires, headers and exhaust, air foil, k&n's gutted air box and a stage 4 chip. what else do i need.
[This message has been edited by 86IROCTHD (edited September 09, 2001).]
Old Sep 10, 2001 | 07:58 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Damn, I got them numbers out of a stock 86 peanut cammed 305.
199 @ 4300 and 269 @ 3300.
BONE STOCK!
Guess that cam didn't help or I have a really tight 108,000 mile motor.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Sep 10, 2001 | 10:24 AM
NUN's Avatar
NUN
mista the 1986 trans am 305 tpi was not detuned like the camero the hp rating was 210 and the tourque was 290 so you can't compare those two cars and also how ddo you no the ta has the peanut cam .also the 86 ta came with those crappy 2;77 gears that why are q-mile are mid 15 lets put 3;42 in it and we would be faster than the 85 iroc and ta they ran high 14.88 bone stock
Old Sep 10, 2001 | 11:49 AM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by NUN:
mista the 1986 trans am 305 tpi was not detuned like the camero the hp rating was 210 and the tourque was 290 so you can't compare those two cars and also how ddo you no the ta has the peanut cam .also the 86 ta came with those crappy 2;77 gears that why are q-mile are mid 15 lets put 3;42 in it and we would be faster than the 85 iroc and ta they ran high 14.88 bone stock</font>
Old Sep 10, 2001 | 01:01 PM
85transamtpi's Avatar
my 85 with 80,000+ miles ran a 15.0 @ 91.5 with K&N and catback, otherwise bone stock. Im not sure that the 86 ta had any different cam than the camaro...I would think that it too would have the "peanut cam" but I'm not sure. I do know that I can beat a stock 87 iroc with LB9...dont know if this helps but numbers seem right with the new cam. If you want more power change the heads to World Torquer 305's . I hear they do very well.
later
Old Sep 10, 2001 | 02:07 PM
formul8!!'s Avatar
Car: 2004 GTO
269 RWTQ is not bad out a stock 305!!!
Old Sep 10, 2001 | 04:15 PM
86 IROC's Avatar
Take into consideration too, the variances between dynomometers.
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
Old Sep 10, 2001 | 05:37 PM
86IROCTHD's Avatar
Car: 88 Trans Am
well mista u run a 15.6 in the 1/4 right, i run a 15.1 with 2.73 gears and its an open diff too with an a4. ;P not bad for highway gears? next thing to come is a set of aluminum L98 heads with a stage 3 port job and swirl polished valves, and portmatching the intake. and a better y-pipe cause my old one is peiced together and that could rob alot of power. also the 86 iroc ran a time of what in the 1/4 and with what gears?
305, TPI,compucam 2030 cam, air foil, 8.8 wires, accel super coil, dynomax headers, custom y-pipe, cut out, 80 series flowmaster, 2.73's and an open diff(3.42-3.73 on the way). and a stage 4 chip :0). hittin a sad 15.2 before the chip.
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reborn756
Sep 4, 2015 03:42 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
