Cant find the fuel fuse to unplug for afpr...
Old Sep 7, 2001 | 01:17 PM
90Iroc-Zee's Avatar
The instructions say that I have to unplug the fuel fuse in order to keep fuel from not spilling out, I would love to install my AFPR but I can't find the fuel fuse in the engine compartment. It's like step 2 in the instructions and if you could help that would be greatly appreciated! THX! Speed Density 90 Iroc 305 is what I have (Manual).
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
Also newly modded w/o track times:
Holley AFPR, Underdrive Pulleys, KYB Shocks and Struts, Crane Ignition
Old Sep 7, 2001 | 01:19 PM
90Iroc-Zee's Avatar
This is the step that is giving me problems...
Releave the pressure in the fuel lines. Take gas cap off, depress schrader valve, remove fuel pump fuse and turn key forward to completely releave fuel pressure.
Heh, I want to put it in SO bad. Thx for the help guys.
Old Sep 7, 2001 | 01:36 PM
rezinn's Avatar
If you can't figure it out, just don't do it. Put a towel under the fuel line to soak up whatever leaks out, gasoline is very volatile, it will just evaporate.
Old Sep 7, 2001 | 02:07 PM
cobrakiller1989's Avatar
I think there is two fuel pump fuses in the fuse panel underneith the dash on the driver's side. The will have "FP" on them. just remove them to be sure and then turn the car on and let it run out of gas. I think that is right. if not, it is worth a try
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*NO recent time slips.
Old Sep 7, 2001 | 02:11 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
The fuel pump fuse has also been reported to be up near the battery... (on firebirds anyway....)
Old Sep 7, 2001 | 02:53 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The fuel pump fuse that is near the battery (also is in camaros) also is the main power feed to the ECM. Which means that if you unplug it, sure the fuel pump won't turn on, but neither will the ECM and thus you won't be able to start it. (this is the handy stealth kill switch as if you don't know these cars you would never think to open the connector to see that it takes a fuse)
What you can unplug is the fuel pump connector that is over the rear axle by the gas tank. Then start the car and after a minute it will stall out. Then you'll be down to practically no FP.
Or, If you let the car sit for a day then your FP should be basically down to nothing as well. This works if you're too lazy to jack the car up.
Old Sep 10, 2001 | 11:16 PM
robert1's Avatar
How about pulling the FP relay?
Old Sep 11, 2001 | 03:36 PM
Ed Maher's Avatar
Car: 04 GTO
Unplugging the relay wont help b/c the fuel pump is powered by the relay and the O/P sender in parallel. The FP won't prime when you turn the key w/ the relay unhooked, but once you get OP it will come on. It's a built in fail-safe mechanism.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
