Edelbrock intake vs. coil bracket
Old Mar 30, 2008 | 08:10 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
hey... i just got my new intake on and realized that my stock ign. coil/vacuum selenoid bracket doesn't fit anymore. where the heck am i supposed to put it now? anyone have some pictures of where you relocated your coils?
Old Mar 30, 2008 | 09:01 PM
Damon's Avatar
Re: Edelbrock intake vs. coil bracket
Wherever you like. I've run them just laid on top of other stuff (temporarily). You're supposed to have the metal "square" armature around the coil grounded to something, but I can't say I've encountered any problems if it's not.
Old Mar 31, 2008 | 10:02 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Those idiots haven't put the work-around in the install instructions yet? I wrote Edelbrock to complain about this (and other things) way back around 1989. They wrote me back telling me to call them. Talking with them, they acted really concerned over this and some other complaints I had.
I was able to mount the coil and the EGR solenoid in the stock location after I removed the center section of the bracket so that it cleared the manifold runner. Then I had to stack some washers behind the bracket to stand it off away from the manifold to get the necessary clearance.
I also had to shorten one of the accessory bracket bosses, drill it oversized (it wasn't drilled deep enough) and retap the hole.
The one good thing they told me was to use Fel-Pro Print-O-Seal lower gaskets instead of the Perma-Torque. But I already knew this.
Old Apr 2, 2008 | 06:32 AM
thunder85's Avatar
Engine: 5.7L w/hsr
well isn't that just handy? i was personally planning on writing them to say how thrilled i was that i had to grind **** off my new equipment so it will fit correctly with the factory stuff its theoretically designed to go with.
on a side note, do you have a picture of the completed bracket modification still? also, which acessory bracket is incorrect?
thanks
Old Apr 3, 2008 | 05:39 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
thanks
No photos. No digital cameras in '89...at least not consumer grade cameras. No film photos either.
I can't recall which accessory boss needed mod'ing either.
Old Apr 3, 2008 | 07:21 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
[QUOTE=paulo57509;3700046]
QUOTE]
I have the TPIS big mouth base, basically the same thing as the edelbrock one and I had to do the same thing.
Old Apr 3, 2008 | 11:23 PM
thunder85's Avatar
Engine: 5.7L w/hsr
Thanks guys... I did that and was just what i needed for now. when i have time i will probably fab a less nasty looking piece, but i am trying to get her back together for the warm weather... spring is finally here in northern NY! the snow is almost gone!!
Old Apr 6, 2008 | 05:51 AM
Pat Hall's Avatar
Same goes for the Accel Superram base manifold too. I also had to cut out the center of the coil bracket between the two intake bolt holes. Only took a few minutes to do though. Kinda hated cutting up a perfectly good bracket, but then I noticed you can get a brand new one from tpiparts.net pretty cheap, so that made me feel better about hacking on it.
Terrell351
Jun 13, 2021 01:13 PM
Fast355
Dec 2, 2016 06:33 PM
Genopsyde
Nov 11, 2015 10:46 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
