Popping Backfiring Issue
Old Mar 31, 2008 | 05:54 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
I recently installed an Accel car and rotor kit along with Accel 8mm plug wires and Bosch +2 spark plugs. Since then my car backfires sometimes pops alot and doesnt stay running until the car has been driven for like 5-10 mintues.(car dies after being started and have to step on gas to start)
I havent replaced the coil yet though, could that be my problem. I also just changed to fuel filter and that didnt help the starting and running condition. I dont have smog or purge canister in car.
Old Mar 31, 2008 | 10:12 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Popping Backfiring Issue
Check that your plug wires are all in the right spots.
Old Mar 31, 2008 | 10:15 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
same post two diff places? Mods might want to fix
https://www.thirdgen.org/forums/tech...ing-issue.html
Old Mar 31, 2008 | 10:17 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
SUre sounds like it.
Old Apr 1, 2008 | 12:49 AM
Car: '87 Iroc-Z
so check my wiring, will do as soon as sun light pops up
no backfire comes from ypipe, I know its running rich cause i can smell it. also im have a broken ypipe right where the cat meets it and i know that is letting in air causing the o2 sensor to tell the ecu im running rich.(i read that out of motorbooks:how to tune and modify your 1982-1998 Camaro)
and yeah it is in two threads, i want all the help
Old Apr 1, 2008 | 11:40 PM
Car: '87 Iroc-Z
bump
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
TBRays98
Sep 6, 2015 05:05 PM
greenyone
Sep 2, 2015 03:39 PM
