replacement fuel injectors
Old Apr 1, 2008 | 05:18 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
what are some good replacement injectors for a L98 with freemods and edelbrock headers and Mac Catback? I think they need to be replaced cause my car wont start sometimes unless i hit the gas and i stalls out if im at a light, though this goes away after the car is driven like 5-10 minutes.
Old Apr 1, 2008 | 05:33 PM
Shamble's Avatar
Car: IROCZ
Engine: LB9
Axle/Gears: posi
Re: replacement fuel injectors
What you can do is OHM out all 8 of your injectors. If it's below 14's, bad injectors. When my injectors went bad my car did the complete opposite. Run fine cold and run erratic hot. try check your IAC valve or maybe your MAF? air filters? fuel filter? vacuum leaks? fuel pump needs to warm up? lotsa stuff. I would consider all of these.
Old Apr 1, 2008 | 07:44 PM
Car: '87 Iroc-Z
i cant test my injectors cause i dont have the tool. please just stick with the question asked!! and by the way runs erratic cold and runs fine warm
Old Apr 2, 2008 | 02:34 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
M9593-a302
cold bad-hot good
Cold running issues (open loop) are not likely to be injector caused.
It is more likely the tune (open loop) not matching the car.
The farther a car is changed from stock the less suitable the stock chip will be.
Old Apr 2, 2008 | 09:13 AM
Car: '87 Iroc-Z
so what to do?
Old Apr 2, 2008 | 03:28 PM
Shamble's Avatar
Car: IROCZ
Engine: LB9
Axle/Gears: posi
Originally Posted by KamikazeIroccy
so what to do?
Multimeters are great to have and can be purchased at any electronics/hardware store for like 10$. If you're going to replace your injectors anyway, do it. I read alot about guys using FORD injectors but Im not sure which ones (Do a search you will find it) , I also remember reading about modifying the fuel rails to do so ( I could be wrong). Obviously SOMETHING isn't working properly when cold. Time for a tuneup?
Old Apr 2, 2008 | 06:11 PM
Car: '87 Iroc-Z
right, and I'm sticking to products made for tpi, i dont want to splice and wires!
Old Apr 3, 2008 | 12:30 AM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
You shouldn't have to splice anything. Many injectors have the same electrical connection. Get a multimeter. If you are willing to spend a few hundred on injectors, you should at least spend $10-$20 for a tool that will be used a TON to test electrical until you track down the true problem.
Old Apr 3, 2008 | 11:04 AM
tpi user's Avatar
with your free mods or a mild tpi 350 stay with stock 22lb injectors,maybe accel injectors may be good.
Old Apr 3, 2008 | 12:50 PM
Car: '87 Iroc-Z
thank you bro
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Firechicken86
Aug 12, 2015 10:07 PM
