differences between 85 and 89 tpi
Old Sep 17, 2001 | 09:58 AM
vinroc's Avatar
I have a 89 vettel98 that I am going to put in my 85 iroc that has the 305 tpi so what I am wondering is is it a even swap
it may be impressive to get a rice rocket to go 12's but why???
Old Sep 17, 2001 | 10:38 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
NOPE, From what I understand, the 85 & 89, although similar are different. You will be better off using the harness & ECM from the 89.
John
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Sep 17, 2001 | 12:00 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Your '85 ECM is alot slower than the '86 up ECM's, and you'd want a new one...the 1989 TPI is still MAF, but does not have a cold start injector like the 1985-1988 unit do...so you'd need a 1989 L98 prom and a newer computer, then you'd need to block off the cold start injector. I'm sure there's other differences as well, you existing prom and computer would in no way work. I'd get a 1989 L98 350 prom, computer and harness, that way you KNOW everything is made to work together...anybody if there's anything I missed let me know.
Old Sep 17, 2001 | 03:12 PM
vinroc's Avatar
thanks guys would you happen to know what would be the correct numbers on the computer and should I try to find the correct fuel rails
evilstuie
Jan 9, 2020 08:29 PM
Wade787b
Sep 29, 2015 01:15 PM
masonta
Aug 31, 2015 10:14 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
