SuperRam + AFR 190cc heads + LT4 HOT Cam = Good Combo????
Old Sep 15, 2001 | 10:13 PM
CamaroX84's Avatar
I was wondering if this setup would be a good combo to go 12s. I am getting some suspension parts to put it to the ground too. Thanks.
Old Sep 15, 2001 | 10:17 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Depends on what size engine youre putting it on. If a 350 that you arent concerned of pumping every ounce of power out...then yes good setup..if a stout 350 or bigger...go with AFR 195cc heads....Im working on a engine for my car...here is the setup I have decided on:
Super Ram intake setup
383 with forged internals
AFR 195cc heads
LT4 hot cam
That setup will definetly get me into the 12s...maybe even the 11s. But with your setup....will probably get you well into the 12s.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cats Coming
More to come.
[This message has been edited by mult68 (edited September 15, 2001).]
Old Sep 15, 2001 | 10:23 PM
CamaroX84's Avatar
It's going on a 355 (350 bored .030" over). I also have a 2200 stall on my 700R4 and a 3.42 posi rear. Thanks.
Old Sep 15, 2001 | 10:39 PM
craiger's Avatar
What are the spec's @ .50 on the hot lt4 cam and what lca? Also, would this cam work well with a supercharger pushing 8lbs of boost? I am putting a new engine together with a set of AFR heads and need a good blower cam? HELP!
Old Sep 15, 2001 | 11:43 PM
ImportsRsloths's Avatar
If its going to be a drag racer type deal go with the miniram however the superram is far more streetable!
Old Sep 16, 2001 | 12:02 AM
mult68's Avatar
Engine: 305 TBI
I would spend the extra money and get 195cc heads. And stick with a superram...unless you have a bit more money to spend and dont have to worry about inspection. But I still perfer the super ram because you wont loose as much torque as the miniram...and Im guessing with that stall converter and gears you wont be pushing past 6500 rpm
Old Sep 16, 2001 | 12:16 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
No. The LT4 Hot cam is too agressive for a blower cam. You want a milder cam with around a 114/116 LSA. I asked the exact same question a few months ago. That would mean boost in, boost out. You want boost in, power out...
I'm using a set of SLP siamesed runners, Edelbrock TPI base and TFS 23* heads (mild ported heads, typical TPI intake porting). I'll be changing to a Superram in the future. I'm using a ZZ9 cam which is somewhat similar to the LT4 Hot cam. I'm pushing my luck, but the same problem with LSA and boost applies with nitrous...I'm still going to shoot it a 100-150 shot of N20. For the price of the cam, the tradeoff for a small power loss is worth it! In the future I'll replace the 350 with a 383 or 396 stroker with the Superram and an LPE 219 cam and AFR heads.
Old Sep 16, 2001 | 05:23 PM
Dan87IROC-Z's Avatar
Yeah, I agree thats a pretty good combo, but use 195 heads if its on a engine bigger than a 350. That setup should be good to about 6250 or so. I have a 377 still in the drawing board that I plan to build thats gonna be good to 7250-7500!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Sep 16, 2001 | 10:51 PM
craiger's Avatar
So, What would you think if i used a custom ground cam @ the same spec's of the ZZ9 With a LCA of 114 or 116? I have the slp runners with the plentum matched to the runners, AFR 190 heads CNC ported, 1.6 crane roller rockers, 24lb injectors, super fmu, Crane hi-6s igntions, headers and flowmaster cat back
Old Sep 16, 2001 | 10:52 PM
craiger's Avatar
Oh yea, almost forgot, paxton sn2000 running 8.5lbs of boost
Old Sep 17, 2001 | 08:34 AM
Kevin G's Avatar
<font face="Verdana, Arial" size="2">If its going to be a drag racer type deal go with the miniram however the superram is far more streetable!
</font>
Both SR and MR are vey streetable.. The Sr isnt far more streetable by any means..The torque issue is also debatable between the two. I would actually pick the MR, even though they both work well. This is coming from a SR owner.
As for the person who asked of blower cams, Comp Cams makes some nice custom grinds.. They also have an off the shelf cc-305 cam, which a lot of guys use for blown setups.. It is 220-230 114 ls, .510 lift with 1.5 rockers.. I think .530 with 1.6 rockers...It is for an LT1, but you can use it no problems in a L-98.. Just check the dowel legnth. It is also emmisions friendly...You should pass dyno testing with a good tune.
Old Sep 18, 2001 | 03:02 PM
CamaroX84's Avatar
What are the advantages/disadvantages of going with 195cc heads instead of 190cc heads in this package? Thanks.
Old Sep 18, 2001 | 04:04 PM
craiger's Avatar
camarox84, I would call AFR and see what they have to say, they have great tech support. I think their number is on the web site? www.airflowsearch.com
CRFred
Feb 7, 2016 11:39 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
anesthes
Aug 8, 2015 09:37 PM
