backfires after headers put on
Old Apr 5, 2008 | 04:42 PM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
I have a 86 iroc TPI 305, I just put hedmen headers on her and acdelco rs43ts the ones in the book, first i put the 44s in and it didnt run right, when i yanked them all out one wasnt firing, Now I put the new ones in and it ran fine for alittle bit but now does the same thing, It idles fine no back firing but when i put into gear it starts. When I had it on the road when it got up to 5200rpm the intake would also sound like its back firing. ANY HELP please this is my baby. lol
Old Apr 5, 2008 | 05:42 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: backfires after headers put on
double check the wires it sounds like you have two crossed firing order 18436572 clockwise very easy to cross the wires ,later jimmy
Old Apr 5, 2008 | 08:17 PM
Car: 86 Iroc-Z
I dont think its crossed wires cause i took them off one at a time when i put the new plugs in, Could it be that I put the o2 sensor to close to the primaries? like I put in on the collector. I also cut the wire and extended it. It has power it just pops when I step on it and its reaches higher rpm, It back fires while in gear.
Old Apr 5, 2008 | 08:27 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
do you have the exhaust hooked up? or just straight headers?
Old Apr 5, 2008 | 08:31 PM
Car: 86 Iroc-Z
exhuast is hooked up.
Old Apr 5, 2008 | 09:19 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
o2 sensor should be fine then,jimmy
Old Apr 6, 2008 | 12:20 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Describe "backfire".. sounds to me more like pops and bangs in the exhuast.. especially if it is happening when you let off at high rpm.
Old Apr 7, 2008 | 11:20 AM
Car: 86 Iroc-Z
ok I found out what the prob was I had the wires crossed, Let the flaming begin! lol, she now runs fine and doesnt pop or anything. Thanks for the help guys.
Old Apr 7, 2008 | 02:58 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
Happens to the best of us. Glad you figured it out.
Old Apr 7, 2008 | 08:38 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
no flaming from me ive been doing this for over 35 years its very easy to do ,good job ,later jimmy
Andrew6.688
Dec 13, 2015 10:59 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Wvcamaro
Sep 4, 2015 08:38 PM
db057
Aug 22, 2015 08:17 PM
theurge
Aug 21, 2015 12:46 PM
