ZZ4 camaro conversion w/TPI??
Old Sep 19, 2001 | 09:23 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Hi everyone, maybe next years plan will be to get the ZZ4 in my 86IROC 305TPI. Would It be easier for me to just buy the crate motor by itself or buy the camaro conversion package. But do I have to change over to a carb or can I keep my TPI setup?? How many more parts would I have to buy, i.e. chip, ECM?? Sorry for the mass amounts of questions at once!
Oh also what oil do you guys run in your engines 305's 350's? I am thinking about going synthetic, maybe Mobil 1? Thanks for any advice!
Old Sep 19, 2001 | 06:06 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Do a search on this board for ZZ4, you'll find a lot of info from several people who have put TPI on a ZZ4 engine, myself included.
Most of us use Mobil 1 10w-30 synthetic oil.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 20, 2001 | 07:58 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I've been using Mobil One 10W30 or 5W30 in my ZZ4TPI
You will need an intake that bolts to older style heads. The aftermarket ones fit both style heads. Any machine shop can grind a stock one cheap.
I swapped my valve covers over (ZZ4 valve covers are both the same and the gromet holes are wrong for a TPI.
The water pump must go for a reverse flow.
I put my small HEI distributor in and put the large HEI that came with the ZZ4 in my 71 Impala.
My engine oil cooler (KC4) would not clear the larger harmonic balancer on the ZZ4 (however you don't need one if you use Mobil One, according to GM).
Everything else was a breeze. The passenger side head is missing one bolt hole for the serpentine belt set up, but there are plenty mounting points, I've had no problems.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
[This message has been edited by Rob P (edited September 20, 2001).]
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
tmellott89
Aug 16, 2015 02:58 PM
stalkier
Aug 13, 2015 12:59 PM
