Would this be a good Combo before I spend lots of money.
Old Sep 21, 2001 | 11:18 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Trick Flow 23*'s , Comp Cam 218/224 .495/.503 112 LSA , 1.6 RR's ,Edelbrock Intake , AS&M Runners? ( I already have the intake and runners) thanks
Old Sep 21, 2001 | 11:19 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
BTW this is on a 89 350 TPI
Old Sep 22, 2001 | 09:24 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
btt
Old Sep 22, 2001 | 12:23 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
With that kind of lift and 1.6 RR's, you will need the upgraded springs on the TF 23° heads.
Yes, that combo will rock. It'll be in the 12's if you can hook.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Sep 22, 2001 | 12:24 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
it's a little vague.what trans?gear ratio?converter?with 218 on the intake side i would suggest a higher stall converter 2200-2400 and 3.42 gears.try going with a thinner head gasket typical smallblock gasket is .041 in. to bump up the compression a bit go wiith a .027 size and a special prom will be needed to maximize the combo.
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
car has found a new home
she will be relocating soon,thanx to all that were interested and the few who had purchased some of the many,many extra parts i had accumulated over the years.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
Old Sep 22, 2001 | 01:00 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I have 3.27's and a stock stall. Thanks Guys
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mustangman65_79
Apr 14, 2017 05:37 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
