Dumb unheard of question for TPI. If ur rebuild ur TPI please read inside!
im probably gonna get laughed at for this but id like to be sure on what im doing. I have the whole TPI dissasembled and i brought a complete FELPRO gasket set, ie. oilpangasket,intake,runner,throttlebodie,headergasket and so on. My question is this, can anyone of u's possible name which gaskets do i need to use silicone sealant on, i heard u dont have to use any silicon sealant on gaskets that are made of rubber is this true?? My most basic question is which gaskets need Silicon,RTV or whatever sealant?????????????? thanx
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
site to see my cars at <A HREF="http://www.geocities.com/iroc_dis/iroc_dis_page.html
1971" TARGET=_blank>www.geocities.com/iroc_dis/iroc_dis_page.html
1971</A> plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
92' camaro
Soon to come!!!
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Except for the above mentioned gasket, put all gaskets on dry.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
86 Camaro Sport
My Camaro Project
i have one more question i have felpros valve cover gasket for center bolt as soon as i tried fitting it on the valve covers or heads the rubber gasket seems to be short i had to strech it to make it look right then it goes back to the short size, can it still work or do i have the wrong gasket???? can i strech it and hold it on the gasket then bolt it on fast??? what do i do??
You stretch them to fit in the rails in the valve covers, and THEN put the covers on the heads. There should be a rail in the valve covers that holds the gaskets on.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
1990 IROC 350
sorry, do header gaskets need any type of sealant??? Which gasket do u suggest i use for the header the edelbrock or the felpro they both look like good quality and good fit which ones would u use????, oh yeah what are the torqu specs for the header bolts im using ARP stainless steel 12point bolts
u don't use sealant on header gaskets. i don't know the torque for sure. i just snuged mine down and they haven't leaked yet
86 IROC-Z
305 TPI
700R4 W/ shift kit
3.23 gears
T-Tops
maroon with gold stickers and rims/ black interior
43,000 miles
flowmaster exhaust, edelbrock headers, gutted airbox, converter, and MAF, K&N filters.
soon to come are 3.73 gears and subframe connecters.
86 IROC-Z
305 TPI
700R4 W/ shift kit
3.23 gears
T-Tops
43,000 miles
The only dumb question is the one unasked. No silicone except for the end-gasket area on the intake manifold base to block. Be sure to use sensor safe silicone or the 02 sensor can fail.
I use a small amount of gasket glue to hold the gaskets to the heads. Be sure to torque the base down in the proper sequence
1st step - slight snug
2nd step - to 35 lb/ft.
The order on the TPI engine is different than a carb manifold for some reason. (this is the order looking at it from above)
Passenger
F 8 7 9 10 11 12
R
O
N
T 2 1 3 4 5 6
Drivers
Install the left runners to the base and torque from the center out to 25 lb ft. Install the right runner to base (loose bolts) Then the plenum to both runners (loose bolts) Torque the bolts in the following order:
1. right runner to base from center out
2. Left plenum to runner from the center out
3. right plenum to runner from the center out
do all to 25 lb ft.
Good Luck
Diesel
Passenger
F 8 7 9 10 11 12
R
O
N
T 2 1 3 4 5 6
Drivers
do all to 25 lb ft.
Good Luck
Diesel
Iroc8t8
May 4, 2026 08:09 PM
Sanjay
Aug 12, 2015 03:41 PM
