383 TPI?
Old Apr 14, 2008 | 07:21 PM
Jcous76's Avatar
383 TPI?
Hi all, I am new to the site and back in the F-Body scene. Its been some years since I have been in one of these but I found a '91 GTA that was to good a deal to pass up. As we all know these cars are and were slow even when rolling off the showroom floor.I was gearing toward an LS-1 swap but I havent seen many mettalic green GTA's around and this car is nicely equipped withthe L-98 dual cats aluminum driveshaft and so on and so on. My issue is now that the car is 17 years old the engine is tired so I had bought another block as well as some other things to make a nice 383. The block is a 1990 four bolt main that is getting punched 0.30 over, Scat 4340 400 crank, Comp Cams Hyd. roller cam specs intake.588 exhaust.609 a set of AFR 195cc heads, Accel Super-Ram and so far thats all. I am looking into pistons as we speak and I am considering going a higher comp such as 10-1 or maybe 11-1. My concern now is the ECM.These cars are a nightmare when it comes to making any kind of real power while maintaing the Fuel injection setup. I really dont want to go through a big expense with a DFI. In the end I will have the car dyno tuned but my question is does any body have a suggestion for injector size, Air to fuel ratios and or ECM solutions so I can maintain the stock computer in the car? I am not looking to make a drag car out of this but the stock L-98 is far from a powerhouse and I would like a clean driver that can keep up with todays technology...
Old Apr 14, 2008 | 07:31 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: 383 TPI?
With a good tune you can use 30 lb injectors. Thats what I am using with no probs.
Old Apr 15, 2008 | 03:38 PM
Jcous76's Avatar
Re: 383 TPI?
Sounds like a good combo, how did you make out with the stock ECM?
Forgot to mention that I have a set of brand new nos SLP headers that will go on and may go with the 3 inch intermediate or if affordable a true dual.
Old Apr 15, 2008 | 08:54 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Re: 383 TPI?
That's pretty much the setup I built. Getting ready to fire it up tomorrow.
Check it out https://www.thirdgen.org/forums/tpi/...test-pics.html
Old Apr 15, 2008 | 08:58 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: 383 TPI?
You may want to look into upgrading your fuel pump. I'm not sure the stock one will be able to handle the potential power output of your motor.
Old Apr 15, 2008 | 09:44 PM
pwdbychevy's Avatar
Re: 383 TPI?
I upgraded mine to a Walbro 255lph. Highly recommended for anything above 400hp.
Old Apr 16, 2008 | 03:45 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: 383 TPI?
This can be a challenge, body has limited room for all the pipes. Ground clearance is also an issue.
Do a search on tgo "true duals"
toronto formula
Nov 10, 2015 06:17 AM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
