cam question
Old Apr 17, 2008 | 06:45 PM
jeepboy180's Avatar
Car: 92' RS 25Th Anniversary
Engine: 305ci TBI
Axle/Gears: 10 bolt limited slip.
cam question
Whats a good mild cam, thats computer compatable, that I can use with my LB9 and world S/R heads??? I figured Id ask for some second opinions.
Old Apr 17, 2008 | 10:34 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: cam question
Cam: Crane Powermax 2032 452/465 214(270)/220(276) 112 deg., 1800 to 5800 RPM (2000 to 5500 RPM), P/N 104224. You may want to use a cam with a bit less duration (like 2 deg. less) and a bit more lift (like .040 more), same LSA if you can find one. (Custom built cam...?)
Springs: Crane 99846-16 125#/383# @ 1.80”/1.20” 1.255/.870 dia. kit, P/N CRN-11309-1 has 99846 springs, retainers, and locks (use the offset locks from the world heads or buy new ones)
Valve Seals: Edelbrock EDL-9725
Shim the springs up .015 (or less) to get to 1.82" install height (which is as close as you will get to 1.80" with these heads)
World heads are built like crap! They shim the springs up so high that they are totally up out of the spring pockets and thus will dance around. This WILL in turn cause them to break the spring dampeners and chew up the crap umbrella seals that they use.
Take my advice: DO NOT install these heads without first changing the valve springs and seals....
Check my Sig for details of what all I have installed on my LB9. Good luck!
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
