Are the TPI units from the 305 and 350 the same.. in a given year?
I'm looking for and would really like to have an IROC with a 5sp and a 350... Of course they didn't make that so, I was thinking of buying a 305/5sp and put in a 350.
But my question is, could I just transfer all the intake stuff over to the 350?
Car: 04 GTO
Transmission: M12 T56
Yes, the intakes are entirely the same. The only difference is the injectors, knock sensor and memcal (chip.)
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
My friend dropped a 350 into his 5-speed TA and the tranney couldn't handle the power and it blew-up. It could have just been his car it was it kinda crappy shape, someone who frequently posts on this board has a 5-speed 350 and it is very fast. His name escapes me now but maybe he could help.
88 Formula 350
Upper and Lower SuperRam, 1000 CFM Accel Throttle Body, 24# Motorsport Injectors, Custom Burned PROM, Larger Gutted Mass Sensor, MSD 6a box, Flowmaster Muffler, Homemade Cold Air induction, TB Bypass, B&M shift Kit, 160* Thermostat
88 Formula 350
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
JR, are you referring to me? There's also Tim Burgess with a 305 5-speed faster than me.
To back up what Ed Maher said, yes, the TPI hardware is identical on a 305 and a 350. The differences are the injectors (19lbs on a 305 and 22lbs on a 350), the knock sensor, the chip, and possibly the EGR valve too. Replacing a 305 with a 350 is pretty much straight foward, there arent any special circumstances you need to know.
About the 5-speed not being able to handle the power, its a matter of luck. Some people's trans have lasted forever, others break right away. I had to replace 2nd and 3rd gear and synchros so far, but I've had no problems with it in the last 6 months.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
The only differences are the injectors, calpak & knock sensor. The 305 injectors can be used at a higher fuel pressure on the 350.
Why not instead get a 350 car and put a 6 speed in it. You wont have to worry about a T5 blowing up the first time you get good traction.
Check out this site. http://www.skulte.com/T56.html
89 IROC-Z 5.7L 2.77 GEARS
130,000 MILES
ALL FREE MODS
K&Ns FILTERS
FLOWMASTER MUFFLER
PERFORMANCE RESOURCE CHIP
AFPR & PORTED PLENUM
Best 1/4 E.T. 14.09 @ 97.2 MPH
Best 1/8 E.T. 9.09 @ 77.4 MPH
Best 60ft. 2.03
[This message has been edited by whiteroc (edited September 19, 2001).]
130,000 MILES
ALL FREE MODS
K&Ns FILTERS
FLOWMASTER MUFFLER
Best 60ft. 2.03
<font face="Verdana, Arial" size="2">Why not instead get a 350 car and put a 6 speed in it. You wont have to worry about a T5 blowing up the first time you get good traction.</font>
Well, because it seems like a general pain in the A$$ to make an automatic car = a manual.... clutch linkage and all (unless there's some kit that I don't know about)
Ghettobird52
Jul 5, 2024 11:18 PM
Sanjay
Aug 12, 2015 03:41 PM
